Multiple Electrical issues
#31
Ok after some research, I think I finally found out where this "radio coke". I've been pretty busy lately so haven't been able to work on my truck but anyway, I think I know where it is. I don't know how to explain it other than behind the center knee bolster, the one in front of the 4wd shifter and goes over the eased part of the floor. I also found a picture:
Not sure if this picture is even for these trucks, It came up in my search one day and thought I'd give it a try.
How do I remove that center knee bolster? It lookes like the whole dash and all the thing screwed in it have to come off. As that is like one piece?
#32
It seems like some type of short or bad ground, But could a short to the speakers or amps cause this problem??
#33
#34
I'm going to call up some local shops that do a lot of radio and electonics work. I wanna see what their experiences are, and possible get an opinion from them on what would be causing the problem. I'll get back to you, but in the man time, I'd also like to start to diagnose cruise contoll. I have no cruise, no light comes on on the each when I press the cruise button. Fuse is good, where would be a good place to start?
#35
#36
For your CC, I would start with the steering wheel switches. There is a procedure in the manual for testing them. Mine were good but my values were different than the manual. Then move on to the brake light switch at the pedal. Mine had one of the two tabs (that keep it locked in place) broken.
https://dodgeforum.com/forum/2nd-gen...l-related.html
#37
#39
I plan to, as those vents are annoying, but that wouldn't explain why I don't have the light on the dash. I've never seen it come on ever, at start up, or by pressing the button. All having the vacuum leak would do would not make cruise hold, but the light would still come on. I'll check that brake switch tomorrow, and also check the buttons aswell.
#40
