Eletrical issues with aftermarket accessories
Hello guys was wondering if you could give me a little guidance on this. I purchased a 2000 Dodge Ram 2500 v10 that has a fuel gauge,trans gauge,oil gauge,coolant gauge, and a vacuum gauge. It also has an electric fan tranny cooler along with electric oil cooler thats relayed and hooked up nicely. After I got home I took off the lower dash assembly and all of these aftermarket accessories and gauges are tied into 1 "run ignition" wire! yikes! 1 wire powering all these gadgets. I was going to leave it, but I noticed theres not enough power to put anything in the cigg lighter. Sometimes the whole "run ignition" circuit will shutdown until I disconnect and reconnect the battery and then it will work perfectly again. Is there anyway to safely power all this aftermarket crap without having to flip another switch? My goal is to get all these accessories to turn on when I cycle the key to "run" would that be possible? Thanks
Okay im following. Basically run relays on the accessories. So run power wire to a relay, and have it switched to the run position. Cool that will probably help aton with power draw. Was wondering how come none of the fuses blew.
