Transmission Noise
Transmission Noise
I see a few having problems with transmissions. I'll add mine. Here is the noise it is making. 86K, was dropped by a automotive box store for the freeze plugs. Driven around 1000 miles before I bought it with no problems. When it's cold, it goes into gear and makes this noise but , not sure how far it will go. When warm nothing foward/reverse and this noise.
https://www.youtube.com/watch?v=8RS_ILdj4Dg
I wonder if when they dropped the transmission the torque converter fell out and when they put it back in it didn't seat all the way. Then if they used the bolts to pull the trans back up to the engine block the not seated torque converter pushed on the pump gears and damaged them.
Not positive, just a thought.
Trending Topics
