P1391 code
Old 02-27-2017, 04:18 PM
Dewayne Gray's Avatar
Dewayne Gray
Dewayne Gray is offline
Default P1391 code
I have a 2001 Dodge Ram 5.9 gas with p1391 code I went to dodge dealer and got a new cam sensor and crank sensor had them installed but still have a sputter and miss with code p1391 coming back on even changed coil /plugs / wires / cap / and rotor cap what else could it be any help will be appreciated
Old 02-27-2017, 04:25 PM
44dakota's Avatar
44dakota
44dakota is offline
the flywheel is the reluctor ring as well, check the windows on it, make sure none are damaged, people like to put long screwdrivers in those windows to rotate the engine over( especially if the engine or trans has been changed) dont ask me how i know this..
Old 02-27-2017, 05:00 PM
dbbd1's Avatar
dbbd1
dbbd1 is offline
Did you catch the replies in the other thread that you posted in?
Old 02-27-2017, 05:03 PM
Dewayne Gray
Yes thanks I posted in wrong place
