Fuel sync question
Old 03-08-2017, 08:26 AM
HeyYou is offline
Dodge Forum Administrator
Received 3,177 Likes on 2,930 Posts
Running a little lean there...... Do you have a tune on your truck??
  #22
Old 03-08-2017, 11:33 AM
nicraage's Avatar
nicraage
nicraage is offline
Yes, I was working with hemifever and he is the one who told me I had a fuel sync issue. I sent him some data prior to me having a zero. I'm going to get some more stc data today.
I guess I asked this question prematurely, as I had a 15 hour day.
I moved my distributor -8 degrees since the tune, and I think I had told him it was originally -12 prior to me getting it to zero.
So essentially he would have tried to adjust + a bunch. Would that lead to "lean"?
  #23
Old 03-08-2017, 12:03 PM
HeyYou is offline
It might..... But, I can't be sure. The injector may spray at the wrong time, but, that gas still has to go somewhere.....
  #24
Old 03-10-2017, 03:07 PM
nicraage's Avatar
nicraage
nicraage is offline
Originally Posted by Moparite
#1 cylinder at TDC
It dawned on me, that I don't think i have the factory distributor. I'm pretty sure I have this one: Davis Unified Ignition. Does the above photo still pertain?
https://static.summitracing.com/glob...w.jpg?rep=True
  #25
Old 03-10-2017, 04:27 PM
HeyYou is offline
Do you have the coil-in-cap type distributor?
  #26
Old 03-10-2017, 04:39 PM
nicraage's Avatar
nicraage
nicraage is offline
I'll have to check. I bought the above a few years ago along with some Taylor ThunderVolt 8.2mm Spark Plug Wire Sets 84276. The wires are on, but it is possible the distributor did not get installed.
  #27
Old 03-10-2017, 06:28 PM
nicraage's Avatar
nicraage
nicraage is offline
well, i know i bought one, but looking at it, it looks different than the summit photo. My mechanic at the time probably gave it back telling me he couldnt get it to work.
  #28
Old 03-10-2017, 06:30 PM
HeyYou is offline
That looks like the stock distributor to me.
  #29
Old 03-16-2017, 06:39 PM
nicraage's Avatar
nicraage
nicraage is offline
Still working on this. I did replace my injectors a couple of years ago. Iput the same ones as here: http://www.ebay.com/itm/5-Yr-Warrant...t/142299431077
My fuel pressure is a solid 50, even while driving. Should this be increased due to the injectors? And if I buy a stronger pump, how do I modify the fuel pressure regulator?
  #30
Old 03-16-2017, 06:48 PM
HeyYou is offline
Pressure regulator is back on the tank, and isn't easily modified..... The O2 Sensor *should* compensate.....
Have you been able to set sync with the scanner?
