New here need help - DodgeForum.com
New here need help
Old 03-12-2017, 11:15 PM
Rowen Anchondo
Rowen Anchondo is offline
Default New here need help
Hello!! New here. I have a 98.5 Dodge Ram 2500 I recently had my blinkers go out. Hazards don't work either. When I use press the brake and turn signal on the bulb is dim but does not flash. I've replaced the flasher, headlight switch, and multifunction switch. I've found a ground behind the inside fuse panel didn't look bad but cleaned and put back. Found another by the front drivers side headlight. Did the same. Still don't have blinkers or flashers. Am I missing something??? HELP!! Please.
Old 03-13-2017, 07:28 AM
jkeaton is offline
Site Moderator
Welcome aboard. Moved to the correct section so you can get some help.
Old 03-13-2017, 09:00 PM
Erin Henrickson
Erin Henrickson is offline
Default bulbs or central timer
Quote:
Have you replaced the bulbs, the gen 2s use a dual filiment 1157 or 3157 bulb and it is possible for the light to still light up but wont flash as it uses the other filament for flashing. Other than that the flashers run through the main timer module and if it is going bad then no mater what other parts are replaced still wont function.
Old 03-13-2017, 10:15 PM
Rowen Anchondo
Quote:
i have replaced the bulbs. What is the main timer module? And where is it located? Thanks for your reply.
Old 03-13-2017, 10:16 PM
HeyYou is offline
Super Moderator
Flasher module is in the fuse block on the side of the dash. On yours, one module deals with both the turn signals, and the hazard flashers.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
