Rear 4.56 gears ? - Page 2 - DodgeForum.com
Rear 4.56 gears ?
Old 03-19-2017, 10:46 AM
getdown78
getdown78 is offline
wear ! I built it almost 3 yrs ago and the pinion preload is still tight but i think the backlash backed off somehow ?
Old 03-19-2017, 10:53 AM
HeyYou is offline
Super Moderator
That would probably do it. I don't think I have never seen gears worn out..... I have seen them blown into a billion little pieces though.
Old 03-19-2017, 11:32 AM
getdown78
ring gear is kinda wore on the edge of teeth but the pinion is just crazy worn ?
Old 03-19-2017, 12:07 PM
HeyYou is offline
Super Moderator
Either bad initial setup, or, something slipped. Need to be changed though.... Cheaper to do it BEFORE they actually break.
Old 03-19-2017, 01:50 PM
getdown78
oh i pulled axles yesterday and cover so it needs to be fixed now ! Gonna order parts today and build it next weekend !
Old 03-19-2017, 02:03 PM
HeyYou is offline
Super Moderator
Good Plan.
Old 03-19-2017, 02:05 PM
getdown78
it will be all brand new parts and seals throughout
Old 03-20-2017, 09:02 AM
getdown78
How much pinion preload do you guys set it at with seal ?
Old 03-20-2017, 05:41 PM
44dakota's Avatar
44dakota
44dakota is offline
20 to 25 ( inch pounds will be good) they also make a spacer with a shim kit to replace the crush sleeve on the 9.25, its very nice because if you ever have to take it back apart, you wont need to buy another crush sleeve, basically just torque the nut back down and you'll have the same preload on the bearing...
Old 03-21-2017, 12:06 AM
getdown78
Quote:
who sells that kit ?
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
