Rear 4.56 gears ?
Old 03-21-2017, 12:21 AM
getdown78's Avatar
getdown78
getdown78 is offline
Who sells the traclok rebuild kit ?
  #22
Old 03-21-2017, 04:17 PM
44dakota's Avatar
44dakota
44dakota is offline
Originally Posted by getdown78
who sells that kit ?
hear you go..
http://www.ratechmfg.com/chryslerspbs.htm
  #23
Old 03-21-2017, 08:14 PM
getdown78's Avatar
getdown78
forget that ! Too much work !
  #24
Old 03-21-2017, 09:30 PM
97ramrod1500's Avatar
97ramrod1500
97ramrod1500 is offline
Honestly, the extra work in the beginning will save you a lot of trouble in the long run, especially if you over crush the first crush sleeve and have to run to the parts store to get another!
  #25
Old 03-23-2017, 11:43 PM
getdown78's Avatar
getdown78
So i got home and parts came in ! Bought the so called platinum gears and master install kit from amazon but i got Motive gear ring gear & pinion and motive install kit so thats nice ! The pinion has some numbers on it but how do i figure out the shims for that number ?
  #26
Old 03-24-2017, 07:29 AM
HeyYou is offline
Dodge Forum Administrator
Received 3,171 Likes on 2,924 Posts
Check the numbers, and shims on your current pinion gear, and do the math.
  #27
Old 03-24-2017, 09:12 PM
getdown78's Avatar
getdown78
exactly how do i do the math then i can figure it out ?
  #28
Old 03-25-2017, 08:25 AM
HeyYou is offline
There is a spec for pinion depth.
There should be a number on the pinion gear face. + or - X number.
Measure the thickness of the shims currently on the pinion gear. (I think they are between the front (larger) bearing, and the pinion gear.)
Add those numbers together.
Subtract the number on the face of the new pinion gear.
That will give you the shim thickness you want to start out. Then measure depth, and adjust as needed.
  #29
Old 03-25-2017, 10:24 AM
getdown78's Avatar
getdown78
Is there a thread about exact procedure on building a diff ?
  #30
Old 03-25-2017, 11:52 AM
HeyYou is offline
Not that I am aware of, but, there are likely some youtube videos.
