94 Ram 1500 5.2l Runs super rich stalls randomly - DodgeForum.com
Old 03-20-2017, 08:41 PM
John Hamilton
John Hamilton is offline
Default 94 Ram 1500 5.2l Runs super rich stalls randomly
Ive got a 94 dodge ram 1500 with the 5.2l that I recently picked up randomly it will cut off if I go to stop as soon as I take my foot off the gas. At idle it runs so rich that you can see the unburnt fuel coming out of the exhaust. I figured that I would reach out to see if anyone had any ideas. Its giving me the egr/ inbalanced air/fuel code 32. I don't have much experience with obd1 and prior vehicles. Any advice or help would be greatly appreciated.
Old 03-20-2017, 08:53 PM
HeyYou is online now
Super Moderator
Check the coolant temp sensor. You have two. A one wire, which is for the gauge. And a two wire, which is for the PCM. That's the one you want. It should be next to the thermostat housing, just to the drivers side.
Welcome to DF.
Old 03-20-2017, 09:03 PM
John Hamilton
Is this the one that is kinda behind the a/c compresser down on the timing cover water pump area? And thank you!
Old 03-20-2017, 10:13 PM
dbbd1's Avatar
dbbd1
dbbd1 is offline
May also want to check the IAC and the port it seats into on the TB.
Old 03-21-2017, 07:43 AM
Super Moderator
Quote:
Yeah, it's right behind the compressor, on the front coolant passage on the intake. Yep. Fun to get to.
Old 03-21-2017, 08:21 AM
John Hamilton
Yeah I ordered on a week or so ago the guy told me the truck randomly would act this way. I had originally replaced the purge solenoid and it fixed it for a little while or so it seemed so I will replace temp sensor today. As far as the iac I'll look into that was well finding a good quality replacement for that seems to be difficult.
Old Yesterday, 08:31 PM
John Hamilton
Replaced egr, temp sensor and iac still running extremely rich. It does have a holley throttle body on it.
Old Today, 07:55 AM
Super Moderator
Which temp sensor did you replace? The one wire, or two wire?
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
