crank no start
Old 03-20-2017, 10:08 PM
iceman02721's Avatar
iceman02721
iceman02721 is offline
Question crank no start
2000 ram 1500 with 5.9. Have a problem that I am stuck on. Truck has spark ,noid pulse,fuel pressure at rail is 45. truck starts if I use either but won't stay running . cap rotor wires and plugs are new . Truck has good compression at 140. Any help would greatly be appricated kind of on a tight budget.
Old 03-20-2017, 10:21 PM
CJSuhr's Avatar
CJSuhr
CJSuhr is offline
Looks like you have ignition, as it's runs with ether. You said you have fuel pressure, but that doesn't mean you have injector pulse. Test for injector pulse, at a few injectors.
If you have no Injector pulse, I would look at the camshalft position sensor, located inside the distributor. That sensor is what controls injector pulse.
Old 03-20-2017, 10:28 PM
iceman02721
as I stated I do have pulse on all injectors
Old 03-20-2017, 10:38 PM
CJSuhr's Avatar
CJSuhr
CJSuhr is offline
Ok. Not sure what was meant by "noid pulse". If everything checks out then, I would scan the computer for codes. You could also try, make sure you take safety to the extreme here, but pull a rail and make sure your injectors are firing. Some freak event could have ruined all the injectors idk. That would be the last to check if I were in the situation lol.
Old 03-20-2017, 11:07 PM
iceman02721
have new injectors on the way did pull rail and had fuel squirt out from injectors but not a good spray new injectors due thurs.
Old 03-21-2017, 07:42 AM
HeyYou is offline
Dodge Forum Administrator
Received 3,177 Likes on 2,930 Posts
Stock injectors will give you a 'pencil beam' spray.
Don't any work to the truck before this started?
Old 03-21-2017, 07:57 AM
iceman02721
the old ones worked but spray was different on 4 of them
Old 03-22-2017, 08:12 AM
HeyYou is offline
Possibly clogged?
How's compression?
Old 03-22-2017, 08:36 AM
iceman02721
compression is good new injectors arriving today or tommorow
Old 03-23-2017, 07:48 AM
iceman02721
new injectors installed same problem possible water in fuel tank
