Replacement steering wheel doesn't fit???
I bought a used steering wheel in great condition and went to install it, but ran into a problem: The steering shaft is splined.
And the old steering wheel hub was grooved to fit the splines.
But the new wheel's hub is not grooved to fit a splined steering shaft and instead has a flat portion with a slot cut.
I can't return the wheel. Does anyone have any knowledge of how to get this wheel mounted?
Didn't know there was a difference between '98 and '01 until I received this wheel. I paid $175, and I can't return it, so I'm not buying another wheel. I'm just wondering if there's an adapter, or if I can swap the steel hub inserts (they look like they're either pressed or molded into the aluminum steering wheel frame.
Trending Topics
