97 ram 5.2 4x4. Poor performance.
Old 03-22-2017, 07:26 PM
jordons2's Avatar
jordons2
jordons2 is offline
Default 97 ram 5.2 4x4. Poor performance.
been awhile since I posted. I'm having a lose of power up hill. When you get up around 2500rpms you can hear a tapping sound. But not at idle or lower rpms. So here is what I've done so far. Hughes plenum kit, cap button, plugs, wires, tps, iac, air filter, pic valve from dealer, cleaned the throttle body,
the only codes I have are for evap purge Sensor
the only things I could think of are fuel pump or fuel injectors. But on my 97 there is no check valve to test pressure.
If if there is anything anyone can think of that I might be missing I would appreciate any help.
Is is it possible that the tapping I hear at 2500rpms and above could be a leaking exhaust manifold.
Old 03-22-2017, 07:55 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,171 Likes on 2,924 Posts
O2 sensors? Clogged cat?
What you are hearing is likely spark knock. Try removing the front O2 sensor from the exhaust, see if the truck drives better.
Old 03-22-2017, 08:01 PM
jordons2's Avatar
jordons2
jordons2 is offline
Default New cat
Forgot I put new cat on right before I did the plenum fix. And if it is in fact spark knock what is the fix for that.
Old 03-23-2017, 07:57 AM
HeyYou is offline
Seafoam down the intake. (carefully. I think there is a diy for this.....) Need to clean the combustion chambers. Also need to verify you don't have any other vacuum leaks.
Old 03-23-2017, 09:14 AM
Sheriff420's Avatar
Sheriff420
Sheriff420 is offline
Doesn't the vapor canister purge valve (solenoid) create a large vacuum leak when it sticks open?
Old 03-23-2017, 09:40 AM
jordons2's Avatar
jordons2
jordons2 is offline
Im not sure exactly how that works. If someone could educate me I would appreciate the knowledge.
Old 03-23-2017, 10:21 AM
jsmith1969's Avatar
jsmith1969
jsmith1969 is offline
Mopar has a version that comes out as foam that is much easier to use
Amazon Amazon
