Engine missing at quarter tank
For about the last 3 months every time I get below a quarter tank of gas in my 94 ram 1500 4x4 5.9 motor starts chugging like it is running out of gas. Truck has about 207,000 miles. If the tank is full or above a quarter runs really well but I'm only getting about 30-40 miles per quarter tank which is very low because before I started having problems I was getting about 80-90 depending on city or highway driving. Have asked a bunch of mechanics and nobody has a clue on why it is doing this. All help is grately appreciated.
There might be an issue with how the fuel pump pickup is placed vs. how the sensor is setup. This would require a fuel tank inspection, probably needs a cleaning by now anyway. Also verifying how accurate the gauge is. When it starts chugging like that it is pretty hard on the fuel pump too, so maybe a replacing it might be worth it. There might be water in the tank also as it is heavier than gas.
Just draining it completely, and maybe sucking out any crap you find on the bottom, will be adequate to the task.
I wonder about the gauge accuracy as well..... Wonder if you are just running out of gas at a quarter tank.
Have you had a look at your plenum yet? Poor fuel economy is a sign of it being blown.
