Sonnax 12861-01
Old 03-28-2017, 03:28 AM
ramdawg01's Avatar
ramdawg01
ramdawg01 is offline
Default Sonnax 12861-01
On a new-to-me 1997 Laramie 5.2 2wd w/ 46-RE trans. did a fluid/filter change, and added a pan drain.
For the record, believe it to be 181,000 actual miles on original engine/trans.
Drilled out the check valve as recommended here in the forums.
Adjusted the bands and replaced the 3-4 accumulator spring with a Sonnax 12861-01, having seen numerous posts recommending this spring.
Thought I had done my homework, but now see that it is NOT recommended for my 1997 Ram 1500 2wd.
I've put on less than 30 miles road testing, and the shifts are nice and firm, though I'm wondering if I should put a new stock spring back, and/or if the Sonnax 12861-01 will cause me problems down the road?
It's gonna be more of a driver than anything else, maybe some light trailer towing to the dumps a few times a year.
Any thoughts, suggestions?
Old 03-28-2017, 07:22 AM
HeyYou is offline
Dodge Forum Administrator
Received 3,170 Likes on 2,923 Posts
If it shifts good, and drives nice, leave it. What makes you think it isn't a good idea?
Old 03-28-2017, 07:59 AM
ramdawg01's Avatar
ramdawg01
I think it's a GREAT idea, but in checking Oregon Performance Transmission's eBay page
for compatibility I got this.....
"This part is not compatible with 1997 Dodge Ram 1500 LT Standard Cab Pickup 2-Door 5.2L 5211CC 318Cu. In. V8 GAS OHV Naturally Aspirated."
This being my first effort on the internals of an auto trans. figured I'd better check with the experts.
Thanks HeyYou, I think I'll be happy with the upgrade.
Old 03-28-2017, 08:03 AM
HeyYou is offline
It's the same trans from 96 to 02....... I am REAL curious just what is different about the 97 model year, that they don't think its a good idea... That's just.... bizarre.
Old 03-28-2017, 09:37 AM
ramdawg01's Avatar
ramdawg01
Actually I think it's just the 'compatibility' function in the eBay listing.
In now looking at the Sonnax website, they show the following.... without mention of
any specific year. I'm keepin it in there for the longhaul for sure.
"42RE, 42RH, 46RE, 46RH, 47RE, 47RH, 48RE 3-4 Accumulator Spring
Part No. 12861-01
Matches OE Diesel calibration
Old 03-28-2017, 05:53 PM
HeyYou is offline
Part No. 12861-01
Yeah, I saw that too. I think you'll be fine.
Old 04-04-2017, 12:34 AM
xjarhead69's Avatar
xjarhead69
xjarhead69 is offline
I have had one in my 96 for years now no issues.
Dave
Old 04-05-2017, 01:07 AM
ramdawg01's Avatar
ramdawg01
Thanks Dave
Got a couple more........gonna put em in a 1998 & 1999 46re.
Old 04-06-2017, 11:09 PM
xjarhead69's Avatar
xjarhead69
You welcome
