Old 08-04-2015, 07:58 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: General Overview
Print Wikipost
DODGE V10 8.0L
Old 02-20-2013, 02:18 PM
flynnzo77's Avatar
flynnzo77
flynnzo77 is offline
Default great truck...need pcm help!!
hey whats up? as for your comment on the truck...i love it, its a great truck the v10 engine can pull a house and you wouldnt even know it! but on my truck i have been having a problem with the pcm computer and i cant figure out why its not charging the battery. this much i know, its not the pcm because all the gauges work and the truck starts and runs fine but its in limp mode and the tranny is in 2nd gear...so if you or anyone hear could help it would be huge...i need to get back to work. thanks
Old 02-20-2013, 03:25 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,164 Likes on 2,918 Posts
This thread is over a year old..... Please start your own NEW thread. (there is a button for that in the upper left of the main forum page.
Old 02-15-2015, 09:05 PM
glenn4x4v10's Avatar
glenn4x4v10
glenn4x4v10 is offline
Default 99 dodge ram 2500 v10 4x4 died and want start back up
my transwent out in my truck so i was going out once aweek starting the truck and letting it warm up but the other day it shut off likke i turned the switch off and hasntcranked back up since ive traced it down to no spark coming out of the coils not sure whats going on truck has never gave any trouble starting or running and was running great when it died
Old 02-16-2015, 10:32 AM
HeyYou is offline
You have two separate modules with coil packs on your engine, need to check spark from both modules. (just look at the coil packs, it'll be obvious which cylinders are on different modules. test at least two cylinders, and see if just one module has failed (getting spark on the other) or, are you not getting any spark anywhere.
Quick Reply: DODGE V10 8.0L
