best tranny oil?
RE: best tranny oil?
I would check with the dealer. Some used Dextron III others used 80-90w and others used some funky $14.00 a bottle crap that the dealer sells. If it was Dextron III I would use Mercon V it's the synthetic version of it and would last just about for ever. Same goes for the 80-90w I would use the synthetic version, but check with the dealer if it is that funky shtuff it is already synthetic.
ORIGINAL: mojo
Just because u are using synthetic doesnt mean that it will last forever. Even the all mighty synthetic fluid does not filter debri. Transmission clutch packs/drums constantly and i mean CONSTANTLY give off particles that contaminate atf. The atf filter is there but most can only filter 250 - 450 mircons, the particles from clutch packs are as small at 30 microns. This contaminated atf then gets into the valvebody, oil pump, and the torque converter. Even worse once atf gets past 40k its gets so contaminated that the temps inside the torque converter increase, which fuels the whole contamination proccess beauce the tranny is running hotter. SO the point is its always better to have fresh regular atf then old synthetic atf. You should ALWAYS change your tranny filter/oil and diff gear oil every 25k. Sure if you can afford 15$ X 9 quarts + synthetic diff fluid every 25k then go for it. But its really the intervals that matter more not what kind of oil.
on
ORIGINAL: greenwood
truck has 207k on original manual nv3500 tranny. shifts fine. what kinda gear oil should i put in her? what kinda transfer case oil and diff oil?
thanks guys
Kyle
thanks guys
Kyle
2004 Dodge Rams were the last Ram's to use the NV3500, and the service manual for that year lists "Mopar Manual Transmission Lubricant" as well. It does not list a particular type (such as 75W85 like it does for the NV4500 in 2004).
Transfer Case: ATF+4.
Axles: It's all over the wall (depending on year, axle size, etc.) Can't go wrong with Synthetic 75W-90 or Synthetic 75W-140. If it's a limited slip, make sure you get the friciton modifier (a bottle of it is like $7 at the dealer).
Manual tranny with a filter? Nope.
