check engine light
RE: check engine light
tonight,for the first time, i got a new code in addition to the p1740.... i am now getting a p1757 and the trans slips when hot and taking off from a stop. so to recap ive got....
codes p1741 and p1757 and a slipping trans when taking off from a stop.
any ideas? im hatin life....[:@] this truck is my only way to work and i have no cash to send to a shop.
p1740-TCC or OD Sol Perf A rationality error has been detected in either the TCC
solenoid or overdrive solenoid systems.
p1757-Governor Pressure Not Equal to Target @ 15-20 PSI The requested pressure and the actual pressure are not within a tolerance band for the Governor Control System
which is used to regulate governor pressure to control
shifts for 1st, 2nd, and 3rd gear (Zero Pressure
Malfunction)
i looked them up in the service manual. hope this helps a little
Malfunction)
Trending Topics
just got mine back from the dodge STEALERSHIP ($75.00 to diagnose it, estimated to repair $700.00!! [:@] i didnt let them fix it, labor rate is too pricey for me considering that parts is only $150.00) ....turns out that the p1757 code and slippage is caused by both the governor pressure solenoid AND the governor pressure sensor. i still dont know about the p1740 since that code was cleared out the last time it came on. i now wonder if the p1757 could cause a p1740...
