RPM Surge??
Old 10-25-2006, 04:29 PM
selling's Avatar
selling
selling is offline
Default RPM Surge??
I have a 1999 Dodge Ram Quad Cab 4 x 4 with a 5.9L. When I am cruising at speed the RMP surges 300-500 RPMs for no apart reason. This surge occures with the cruise control engaged and when I am driving normally. The truck accelerates and idles with no issues. I had the rear diff speed sensor changed by a licensed mechanic about 2 months ago, but the RPM surge just started this week. Does anyone have an idea what I can check to fix this?
Thanks
Old 10-25-2006, 04:32 PM
Racinfan83's Avatar
Racinfan83
Racinfan83 is offline
Default RE: RPM Surge??
99% chance that your Throttle Position Sensor is bad. You can get one at most parts stores for roughly $35. You can change it yourself in 5-10 minutes.
Old 10-25-2006, 04:41 PM
selling's Avatar
selling
selling is offline
Thanks for the reply.
If it is the throttle position sensor would it show up as a code? No codes are registering. Thanks again
Old 10-25-2006, 04:54 PM
steve05ram360's Avatar
steve05ram360
steve05ram360 is offline
no it wont. the sensor starts getting noisey and the pcm thinks it needs to un-lock the torque converter so thats what it does. I have never heard of any of these failures throwing a code.
Old 10-25-2006, 05:47 PM
Racinfan83's Avatar
Racinfan83
To add to what Steve said - I had the surge problem almost from the day I got my truck new. I had the dealer check the tranny out several times because I just knew something wasn't right. The dealer techs could never find the problem., even after rebuilding my tranny twice under warranty after it burnt up. I found out about the TPS on here - and it fixed the problem. I let the dealer know what the problem was - they had no clue because their computer diagnostics didn't tell them.....
I firmly believe that the bad tps on mine is what caused my tranny to burn up twice - due to excessive shifting and converter lock/unlocking
Old 10-25-2006, 06:27 PM
BryanRachko's Avatar
BryanRachko
BryanRachko is offline
Can someone help here.... I just received Code 1763 on the way home. I searched for it but can not seem to find out what the issue is or where to start? Can anyone help? I just had the throttle body cleaned, new plugs and wires done on the truck last week. Any ideas. The truck is starting to lunge and surge. Thank you.
Old 10-25-2006, 07:22 PM
steve05ram360
code 1763 does not exist in the list I have, maybe someone else can chime in.
Racin, do you remember the thread about the wiring issue that was causing a similar problem that was in the tranny? I've been looking for that thread and cant seem to find it. did you ever see it (and save the link)?
Old 10-25-2006, 08:24 PM
TMS Bill's Avatar
TMS Bill
TMS Bill is offline
OBDII Code P1763 - Governor Pressure Sensor Volts Too High (Chrysler, Jeep)
Now ... what's THAT mean?
Old 10-26-2006, 04:48 AM
Racinfan83's Avatar
Racinfan83
ORIGINAL: steve05ram360
Yeah, Steve. I will find it in the next 24 hours or so and pm it to ya......It's on my home 'puter - I'm on the work 'puter now.....
Old 10-26-2006, 02:30 PM
steve05ram360
it means a the sensor in the tranny has gone bad... take it to a tranny shop and have them swap it out and do a servicing on it. there is another sensor in there that also goes bad, i'd have them swap that one out while they are in there. I had a tranny problem that related to that sensor, never thru a code and it turned out to be one of the 2 sensors inthe tranny. fixed it and never had a problem again.
Quick Reply: RPM Surge??
