popping sound from exhaust = leak?
i've been told by sea foam in an email that the noise i started hearing after using mopar combustion chamber cleaner, the popping, cool, mean street, exhaust sound as the RPM's go back down, is in fact an exhaust leak somewhere in the system. now how could this be true? i've only started to hear it after using the cleaner. although i did notice a little puddle underneath one of my pipes in the exhaust system after using the cleaner, i'm sure that was like that the whole time.
anyone know about this?
RE: popping sound from exhaust = leak?
The puddle is most likely just condensation, and is normal. The noise though, might not be. Does it happen all the time, just louder sometimes, or is it only on decell? All the time is definatly a leak, not all the time is detonation in the exhaust caused by unburnt fuel in the system. Kinda need more info to tell ya the exact cause. Like where the noise is coming from (under truck or under hood), and when exactly it happens.
its a normal noise. All cool cars do it
actually the noise is the result of unburnt gasoline going through the combustion chamber. That means the vehicle runs rich, not abnormally rich, but rich none the less. From the factory most vehicles will run slightly richer than optimum for detonation safety issues. If you dont like the sound, you can get your pcm retuned so that it runs at optimum a:f. which is usuially the infamous 93 octane setting.
ORIGINAL: mntnceguy
And I do like it, in fact when i'm just rolling along in a parking lot i'll switch it over to neutral and give it a rev or two :P
ORIGINAL: ripto
Only happens on decelleration and from the back of the truck, where the exhaust exits. Sounds just like any old mustang you hear with some guy who thinks hes cool and revs it up at a light, that noise the exhaust makes when the RPM's are going back down.
ORIGINAL: mntnceguy
Trending Topics
My old Ramcharger with cherry bombs and no cat used to do it something awefull!! It was cool as hell, I'd drive up next to somebody that was slowing traffic, and scare the **** out of them with it. Anyway, yeah its just unburnt fuel in the exhaust igniting, not really a problem, although sometimes it can cause the cat to fry if it is occuring far enough up in the exhaust. That is kinda rare though. Have fun scaring little children!!![sm=badbadbad.gif]
