Door hindge replacements are a waste of time and money. If your door sags, take washers and put the on the door side of the bottom hindge, doing that will raise up the door. I spent $30 for new pins when a 10 cnet washer fixed the sag.
Sounds more like a bandaid than a true fix. That's not going to fix the worn bushings and holes.
So do pins and bushings, and they last longer as well. Your hinges will continue to deteriorate, as there are no bushings any more.
Ok, so the new pins and bushes did help, im not disowning the fact that they were wopped, what i was trying to say in a hurry was that although the bushings and pins helped, it didnt completely line my door up, which is where the washers came into play. The washer is what finished the job. Thats all, i misspoke in my first reply
I had to loosen the bolts, and re-adjust the hinges on mine. I guess everything sags a bit over time.
