DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Trucks > Dodge Ram > 2nd Gen Ram
Thread Tools Search this Thread
  #71
Old 07-10-2009, 05:30 PM
zman17's Avatar
zman17 zman17 is offline
1998 Dodge Ram 1500
Try Rock Auto
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
__________________
98 1500 4X4 5.2,SC3815, HS 1.7's,Borgeson shaft,
Fastman TB, Hughes Plate, 4x4 Posi-lok
Magnaflow Cat. w/Flowmaster 50 series, Rock Solid Ram Steering fix
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
  #72
Old 07-23-2009, 09:19 AM
rstiner rstiner is offline
I will also be doing this to my 1999 2500 V10 in the next week or 2. Glad I found this thread. Anyone have any adidtional helpful hints. It looks like you do not have to take the face of the dash off correct? What acually fails on the evap the body or return bends, and from vibration? Looks like quite a lot of Dodge trucks have the same problem. Also I do not see where you have to do anything with the rt air bag?
  #73
Old 08-06-2009, 09:18 AM
planetb's Avatar
planetb planetb is offline
Default Rockauto prices.
I just picked up all the following from rockauto :
ACDELCO 151852 (15-1852) A/C Receiver Drier $ 34.89
FOUR SEASONS 26782 A/C System Valve Core and Cap Kit $ 18.05
FOUR SEASONS 54166 A/C Evaporator Core $ 83.79
SPECTRA PREMIUM 94466 Heater Core $ 54.79
Discount $ -9.58
Shipping Location 1 Ground (FedEx or UPS) $ 7.58
Shipping Location 2 Ground (FedEx or UPS) $ 7.02
Order Total $ 196.54
Shipping seemed pretty high, but the $9 discount helped. I don't trust my low pressure side valve, so got a valve core/cap kit also.
  #74
Old 08-07-2009, 12:15 PM
capsap33 capsap33 is offline
1999 Dodge Ram 1500
I picked up a set of those "China" Freight Tools A/C Manifold gauges - work and are pretty good quality. I no longer guess at whether or not I have the correct amount of R134 - its right on and I havent had A/C probs since using it. I also checked the owners manual on my 99 Dodge Ram 1500 360 5.9 V8 and it states specifically when using "Max" A/C that once you get the temp comfortable, you should switch to Non-Max setting. I did that and have noticed that it works great when doing so. It also drips mega-condensation, too - something it hardly does on Max.(?) But I now reserve use of the Max a/c to what the owner manual states and when I am in sitting traffic (dont like breathing other car's exhaust) and extreme conditions, using non-max when on highway (moving). Since I started this practice my A/C is working awesome (not to mention that the gauges helped). Note - I also had a water hose running water over my condensor and set the R134 can in a bowl of hot tapwater when filling - seen that on Davidsfarm instructional video (utube) and another great A/C maintenance Utube video - worked for me . . .
  #75
Old 08-09-2009, 12:12 PM
Default looking you the time now
Still trying to find time to do this. I put some stop leak in and added some charge seems to be holding charge for now. Only time is holding me from doing it now. Any answers for the questions on my last post?
  #76
Old 08-10-2009, 09:32 AM
planetb's Avatar
Quote:
I asked about the airbags and was told to just unhook the battery 30mins before you start. No idea on why it leaks yet myself. Once the water gets better out (cooler) I will replace mine. I got all my parts on Sat from rockauto.
__________________
87 Shelby Lancer
99 Dodge Ram 2500 Cummins
04 Dodge Neon SRT-4
07 Dodge Nitro
  #77
Old 09-19-2009, 08:12 PM
planetb's Avatar
OMG. That was painful. Did mine today. took 3 hours to get it apart. I didn't have the directions. Just did it via memory. 2hours to rebuild the heat box (had to redo some of the weather stripping that feel apart..) and then started putting it together around 3pm and finished charging the system at 6:30. so about 3 1/2 hours to put together.. 1 hour auto part store run and lowes run to get some weather stripping. 30mins for lunch and 10mins for bathroom and beer breaks.. Not issues other then running out of beer. but I was surprised what I found on the evaporator..
Eww! did fine the green dye on the evap. so guess it really was leaking Heater core looked good, but replaced it aways..
__________________
87 Shelby Lancer
04 Dodge Neon SRT-4
07 Dodge Nitro
  #78
Old 10-05-2009, 01:35 PM
clang3471 clang3471 is offline
Vehicle: 2001 Ram 1500 SLT 4X4
Thanks everyone for the instructions, pics, and tips. Did my heater core and evap on Sat and everything went great. Only thing I can add is to remember to hook the vacuum line up in the engine compartment. I made sure I had enough beer before I started!
  #79
Old 10-06-2009, 10:44 AM
Default still holds
Mine is still holding charge used the super stop leak, I know its not a perm fix but I am not sure how long I am keeping this 2500 V10 gas hog.
  #80
Old 11-03-2009, 09:16 PM
PurplDodge's Avatar
PurplDodge PurplDodge is offline
1999 Chevrolet S-10
My Garage
Vehicle: Dont drive....
Quote:
Originally Posted by VWandDodge View Post
OK, got my heater core from Rock Auto (http://www.rockauto.com) and it is the exact match to the OE core. It's copper/brass wrapped in foam. I got some foam from a local hobby store to replace the piece that goes between the core pipes and the firewall. Here is what the new setup looks like:
What brand was that copper/brass core?
__________________
My name is Nathan and my tank is full
Oil Change DIY Plenum Gasket Repair FAQ
Tags
2000, 2003, ac, accumulator, caravan, condenser, core, disconnect, dodge, durango, evaporator, heater, hose, lines, neon, removal, replacement, stuck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
