spray the top of the steering box with a little brake cleaner to clean the dirt off.
work on the truck from underneath. key turned on one notch to unlock the steering wheel, but truck not running. wheels on ground.
use a 16 mm wrench and a 4.5 mm hex wrench (i think, if not 4.5, then 5.0)
insert the hex wrench into the center of the adjusting screw and point it towards the front of the truck.
hold the hex wrench and loosen the locknut.
have wife, g/f. wiggle steering wheel, or else get up and down a lot.
tighten hex wrench about 1/4 turn at a time to take up the play. i turned mine about 3/4 turn to take up 2 inches of play in the wheel.
hold hex wrench and tighten locknut.
you're done, take it for a test drive.
if you go too tight you will feel it "binding" when you turn if its too tight it will cause premature ware on the steering box
DodgeForum.com and myself will not be held accountable for any problems resulting in doing a modification you found on our site. This includes, but is not limited to; faulty outcomes, legal issues, broken parts, undesired outcomes, injuries and so forth.
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on Dodge Forums!
__________________
^^ sorry for the poor spelling
1998 Dodge Ram 1500 4X4 318 (5.2L)
too much to list....
Sponsored Links
Registered users do not see this ad. Click here to register for free!
