DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Trucks > Dodge Ram > 2nd Gen Ram
Thread Tools Search this Thread
Old 07-25-2007, 02:13 AM
ryans590 ryans590 is offline
Default DIY tranny filter/fluid change
tranny filter/fluid change DIY
done on a 98 5.2(318) 1500 with a 46RE tranny (auto)
1. remove the dozen or so bolts holding the pan on (take them all out but one side then lower it down to slowley let the oil out otherwise youll have a mess) {pan bolts are a 13mm socket}
2. remove the 2 toqurx screws holding the filter on {screws are T20}
3. scrap off all the olf gasket this can be a PITA good gasket scraper will help
4 cleen all the gunk of the magnet in the pan
5 put new filter on {mine was an ATP P/N B-175}
6 line up gasket on pan ( i used a little grease to hold it in place) {be sure to use a new gasket and not RTV or any sealent my filter also came with a new gasket}
7 bolt pan on tq to 25 ft lbs
8 re-fill tranny with aproprate fluid (ATF+4)
ittl take 5-8 quorts depending on how long you let it drain {when i did mine i took the pan off dumped the oil out but had to wate for the right parts before i could put it back together this took about 3 days i had put the pan back on inbetween so nothing would get into my tranny when i took the pan back off it was about 3/4 full again. might be a way to get a little more fluid out when changing it if you can let it sif for a bit}
be sure to check it in nutral with the truck ideling and at opp temp.
DodgeForum.com and myself will not be held accountable for any problems resulting in doing a modification you found on our site. This includes, but is not limited to; faulty outcomes, legal issues, broken parts, undesired outcomes, injuries and so forth.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
__________________
^^ sorry for the poor spelling
1998 Dodge Ram 1500 4X4 318 (5.2L)
too much to list....
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 08-15-2009, 05:42 PM
joshb joshb is offline
it needs to be 13 ft lbs not 25. I broke a bolt using 25
Old 08-15-2009, 07:31 PM
fjmg fjmg is offline
I am amazed that you broke a bolt before stripping the threads in the alum. case! I stripped two and picked up a heli-coil kit to repair them. However, I used the rubber gasket with metal sleeves at the bolt holes which is alot thicker (about 3x) than the cork gaskets and hence the bolts do not engage all the threads completely. maybe I should use longer bolts?
Old 08-15-2009, 10:45 PM
dblj16380's Avatar
dblj16380 dblj16380 is offline
1999 Dodge Ram 1500
Vehicle: 1999 Dodge Ram 1500 4X4 5.9L V8
I found out when I rebuilt my trans last year that the cork gasket is designed for the original 727 trans but fits ours (basically the same trans except for hydraulic and no OD) and the rubber gasket with the metal is designed for our 46RE's! Plus the trans pan should have a total of 14 bolts!
Just my $0.02!
__________________
'99 Ram 1500 Club Cab 4X4 5.9L V8 Automatic.
Caution: Don't fall asleep and hit signs! They don't like fast moving trucks!
Old 09-10-2009, 12:09 AM
CowTownRam CowTownRam is offline
I was chatting with a buddy of mine who was told by 3 different mechanics that they would not touch his automatic tranny to change the filter and fluid. They ALL referred him to see a Tranny shop instead (no not the same shop either).
Have you EVER heard of this before? I mean, sounds like a piece-o-cake job to do. Unbolt the tranny pan, drain, clean pan, put on new gasket, replace and retorque bolts and refill....where is the difficulty or danger in that???
Why in the world would someone HAVE TO take it to a tranny shop?
Old 09-10-2009, 02:15 AM
xray99's Avatar
xray99 xray99 is offline
Vehicle: 1996 1500 SLT
Also a good idea to check the bolts after a few days and retorque, as needed.
They often work themselves out a bit after a new gasket install, and once the fluid forces itself out through any weak spot, your screwed and have to do it again.
__________________
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Tags
auto, change, cork, dakota, diy, dode, dodge, drain, filter, fluid, gaskets, lines, ram, tranny
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
