DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Trucks > Dodge Ram > 2nd Gen Ram
Thread Tools Search this Thread
Old 08-30-2007, 09:44 PM
SmokeGrinder's Avatar
SmokeGrinder SmokeGrinder is offline
Vehicle: 2000 Ram 1500
Default FIPK No More Picture Tutorial Step By Step: Breather UPDATE!
Heres your basic supplies you need...
14X3 Airfilter ( You can go smaller but no bigger)
Threaded Rod
Breather
1/2" Throttle Body Spacer (Clears the lines, Mr. Gasket worked nicely)
Sawsall
Vice/Pliers/Leverage Bar
Heres the threaded rod you need..... 20" 1/4"
Heres the breather.... no stores had 1" but 1" 1/4 should work since most people said there 1" was alittle loose....
Now for the threaded Rod, Heres your basic plans to follow..
I bought 3 Feet of threaded Rod....Notice the Nut on the end, Use this so that when you cut the rod you then take the nut off and it rethreads the rod for you...
Bend it 3/4" to center the offset...
Next you need to start taking apart the stock air filter box....
First unscrew the clamp using a flat head screw driver...and remove the vacuum line from the stock airbox...
Now squeeze the ends of the stock CAI and release from the passanger side fenderwell....
Now, pull the hanger out of the rubber grommet located above the alternater...
Almost there.....Now lift off factory airbox,and screw in your custom made S-Bolt
Heres your throttle body.....Reminds me of a 2 barrell carb....NOTICE: the offset thread, this is where you S-Bolt comes in....
Now place your old school air cleaner ontop and tighten down...
Now Enjoy!
UPDATE!
I didn't like how the edelbrock breather looked so I made this....
Heres what I did:
Took out stock grommet and put the edelbrock in, it looked decent but i felt like i could make it better. So I took a trip down to AA Auto and got a vacuum line breather that matches the AC. Next I took the stock grommet and cut it to have a flat nipple. Finally take your new breather and tighten over your custom made grommet. NOTE: The air cleaner vacuum line comes off in sections so you dont have to break the whole thing, only the endpiece.....Enjoy this one, haven't seen anyone else do it this way.
Heres some blunders I made....
Heres the hose attached to the airfilter that I broke the end off....
Heres A good picture of what you need to pry off your valve covers....
Thanks to Silver....and all the rest who helped me out....
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 08-30-2007, 09:49 PM
2500 mopar 2500 mopar is offline
Default RE: I need HELP IMMEDIATELY FIPK NO MORE PROBLEMS...PICS...my dads going to kill me
id try to use pliers or a flat head screwdriver, wedge the screwdriver between teh valve cover and the tube and pry
__________________
2001 DODGE RAM 2500HD 4x4 5.9L V8 360 w/
46RE tranny
LARAMIE SLT
4.10's Dana 60's
Line-X
remote start
MODS:
NGK's
dual exhaust with super 44
180* t-stat
Mopar air cleaner
Edelbrock breather
Old 08-30-2007, 09:51 PM
So is this a rubber grommet you have to pull off? I was pulling by hand so hard thats how i broke it....I'll try screwdriver and pliers prying.....Anyone have any input that took this off before?
Old 08-30-2007, 09:54 PM
WayneC WayneC is offline
Just stick a heavy screw driver in the broken piece and pry it out.
Excellent pic of the VACUUM CHECK VALVE IN THE TEE THAT GOES TO THE CRUISE AND A/C EVERYONE!!!
__________________
2001 1500 Quad Cab; Auto, 5.2
Still Playin' With Trucks!
Old 08-30-2007, 09:58 PM
yes this should just pull off, it probably has suction on it though
__________________
46RE tranny
LARAMIE SLT
4.10's Dana 60's
Line-X
remote start
MODS:
NGK's
180* t-stat
Mopar air cleaner
Edelbrock breather
Old 08-30-2007, 10:01 PM
Ramdamit98's Avatar
Ramdamit98 Ramdamit98 is offline
Vehicle: '05 Ram 1500 SLT
I found it easier to pry the grommet out with the piece and then separate them after.
__________________
'05 Dodge Ram Daytona #08090, 5.7L Hemi, 4x4, Auto, 3.92 Gears
Superchips 3815, 17" Moto Metal Rims, Airaid MIT
Silver Truck Club Member #14
Old 08-30-2007, 10:03 PM
Thanks, I'll do that now....I'm changing this thread to a pic tutorial
Old 08-30-2007, 10:12 PM
Fox Fader Fox Fader is offline
YOu need to stick something like this in there.
__________________
Sold
Sat for six hours.
Gone in 20 minutes.
Old 08-30-2007, 10:31 PM
why? everyone else I saw used the breather...
Old 09-01-2007, 12:36 AM
ttt
Tags
2nd, breather, cai, dodge, gen, grommet, mopar
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
