DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Trucks > Dodge Ram > 2nd Gen Ram
Thread Tools Search this Thread
  #21
Old 11-01-2007, 12:49 AM
Sirhilton17 Sirhilton17 is offline
Send a message via AIM to Sirhilton17
Default RE: rear drum brake *CHEAP UPGRADE*
I think I am going to do it... I cant keep my front rotors from warping... so maybe if I get more braking power in the rear it will stop warping them...
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
__________________
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
  #22
Old 11-01-2007, 03:52 AM
nateblong nateblong is offline
Vehicle: 2000 Dodge Ram
Wow I never thought of that....But it makes perfect sense. I mean of course we all wish that our 1500's were 3500's, yah know..........well unless your running a 2wd.....good info..
__________________
2000 Quad Cab Sport, 5.9L, 46re, from the cat mandrel bent duals, no mufflers, K&N fipk, 35/12.50/18 Toyo M/Ts, KMC wheels. Superchips 3815, Hell bent 2inch leveling spacers front, 2 inch Skyjacker add a leafs rear. 8.5mm MSD wires, Screamin Demon coil, brass distributor and rotor, Autolites. Always Mobil 1.
  #23
Old 11-01-2007, 05:14 AM
steve05ram360 steve05ram360 is offline
Site Moderator
Dodge Forum Moderator
Vehicle: 2005 Ram CTD 4x4, 2000 audi TTQ
Quote:
ORIGINAL: Silver_Dodge
And what exactly were the types of improvement you saw from doing this?
Good write-up. We should have this added to the DIY section. Nice work.
added...
__________________
http://www.dodgeforum.com/m_1037052/tm.htm
http://s41.photobucket.com/albums/e266/sdoherma/
  #24
Old 11-12-2007, 01:24 AM
LPIdaho LPIdaho is offline
Well just completed this upgrade so here is my experience;
I over paid at $18 each at Checker, but they were in stock and I was all excited to get this done.
This is my first vehicle of any sort and I've never taken brakes apart before so when I pulled theshoes off and everything fell off I got kind of fightened. haha
I didn't do any definitive before and after testing but it seems to have helped some.
What I likely need to do is improve the front now.
But most importantly just follow the steps listed above and this is quite easy and bolts on.
Any idea why my brake and ABS light were on for quite a while?
It took awhile to bleed the lines but I'm just kind of happy to have taken the brakes apart, put them back together and have them work properly.
  #25
Old 01-07-2008, 01:39 PM
pcfixerpro's Avatar
pcfixerpro pcfixerpro is offline
2001 Dodge Ram 1500
Vehicle: 2001 Dodge Ram 1500 QCSB 4x4 5.2L
did anyone ever determine if you can do this mod for 01's with drums in the rear. Someone said something about they changed the brake style in the 01's and was curious if you could still do the same mod?
__________________
2001 Dodge Ram 1500 QC SB 4x4, 5.2L, Forest Green
Check her out here http://www.cardomain.com/ride/3140057
  #26
Old 01-07-2008, 01:59 PM
ICEMAN_CH ICEMAN_CH is offline
2001 Dodge Ram 1500
Vehicle: 2001 Ram QC LB
I think that aimsforsquirels tried it on his 01 and ended up ruining the drum. He wasn't very happy.
__________________
2001 QC RAM LB HD - 285/75/16 - 3:96 gears (came stock - Hughes Plenum kit - Cloyes double roller timing chain (advanced 4) - 180 T-Stat - Flowmaster Delta 40 Dual Exhaust - Pacesetter LT - Hypertech set to 93 octane
  #27
Old 01-07-2008, 02:54 PM
aim4squirrels's Avatar
aim4squirrels aim4squirrels is offline
2001 Dodge Ram 1500
Vehicle: 2001 Dodge Ram 1500 5.2L 2WD Reg Cab Long Bed
Quote:
ORIGINAL: ICEMAN_CH
Correct:
http://www.dodgeforum.com/m_1082846/mpage_3/key_/tm.htm
__________________
  #28
Old 01-07-2008, 03:42 PM
greenmachine greenmachine is offline
2001 Dodge Ram 1500
Vehicle: 01 QC 5.2 2wd
Quote:
ORIGINAL: Obiejuankinobie
Does the 2001 1500 2WD have drum brakes??????????
Some do. They had both style brakes that year.
__________________
My vid:
http://s228.photobucket.com/albums/ee258/chevyjunky77/?action=view&current=100_1689.flv
  #29
Old 02-23-2008, 10:38 AM
VWandDodge's Avatar
VWandDodge VWandDodge is offline
Vehicle: 1997 Ram 1500 4x2
I've been running this wheel cylinder upgrade since last fall, and I must say it is one of the best modifications I have made to my truck. It took a while for the self adjustors to kick everything into place, but now, when I'm out driving, the rears lock up *RIGHT NOW* in panic situations. I can made the rear wheels screech with ease if needed. I recommend this swap to everyone on this board.
__________________
<< Insert long list of crap that's been purchased and bolted on to said vehicle here >>
  #30
Old 02-23-2008, 11:04 AM
Houston4x4 Houston4x4 is offline
Quote:
ORIGINAL: VWandDodge
So you don't have ABS?
Tags
1500, 1998, brake, brakes, cylinder, cylinders, dart, dodge, drum, installation, mods, mopar, ram, rear, upgrade, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
