DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Trucks > Dodge Ram > 2nd Gen Ram
Thread Tools Search this Thread
Old 01-25-2008, 08:27 PM
SilverRam_01 SilverRam_01 is offline
2001 Dodge Ram 1500
Default MIL+P0158
'DTC P0158 H02S Circuit High Voltage Bank 2 Sensor 2' Noticed a check engine light and got a P0158 from the Odometer- anybody know what this is... computer codes and stuff is all chinese to me- appreciate any input!! Thanks!
*Figured it was the O2 sensor. For some reason I only have 1. Checked the whole exhaust system over in the rain, and only have one, right on the y-pipe where it becomes one. There never was one behind the big cat, and there's nothing there now... nor is there any cut wires or anything resembling a simm. WTF? Is it gonna be not such a good idea to drive this thing like this? I need to be able o drive it about 100 miles everyday... Thanks!
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
__________________
"White Trash Special"
2001 1500 RCSB 2wd, Cherry Bomb Extreme, modded Kegger, 180* T-stat, 3923s, Pioneer deck and Sony Xplods, Edelbrock Pro Flo triangle air cleaner, no cat, flat black and ugly.
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 01-25-2008, 09:05 PM
TheForce55555's Avatar
TheForce55555 TheForce55555 is offline
Vehicle: 2005 Ram quad cab hemi
Default RE: MIL+P0158
HMMMMMMMMMMMMM, I have no idea, I HATE computers and wires. you should probably have 2 02 sensors, can you see any wires hanging by the rear of the tranny
__________________
Daily Driver - 05 1500 Hemi quad cab, 3.92's, lsd in the rear, 17" Eagle alloy wheels wrapped with 295/70/17 Nitto terra grapplers, Superchips 3865, vararam intake,dynomax cat back, Synthetics all the way around
Old 01-25-2008, 09:07 PM
rabbler rabbler is offline
1997 Dodge Ram 1500
There should be one it the pipe after the Cat, thats OBD II spec. By your sig I looks like it was all chopped off and straight piped. Maybe somebodycut off the connectoror tucked it out of the way.
Is this truck new to you? I would think the MIL would have come on long ago if this was the case.
__________________
97 Ram Sport ext 4x4, 5.9L gas, 3" pro comp lift w dual shocks, 3:55 trac lock
Lt305/70R16 Kumho KL-78, K&N FIPK, Mopar Performance wires and cap, Stainless shorty headers, Walker exhaust. All syn lubes. Sirius sat radio! Magellan GPS
2003 Grand Caravan Sport. 3.3L No toys in it. Nobody's cool in a Minivan...
Old 01-25-2008, 09:58 PM
2001 Dodge Ram 1500
I just checked, and I do have 2, but they are right after the little cat-things on the downpipes. Then it Ys into one pipe, and theres the big cat, and there never was an 02 behind that... I've had the truck for ~30K and it just finally threw the 02 sensor code, bank 2.... anybody know what side that is so I can just replace the faulty one??? Thanks for the replies..
__________________
Old 01-25-2008, 10:20 PM
Sirhilton17 Sirhilton17 is offline
Send a message via AIM to Sirhilton17
I got the code a few weeks ago when the truck was idleing in the driveway, I took the truck to autozone and used the scanner there to erase the code and it never came back... I would try that... maybe its just a fluke.
__________________
Old 01-25-2008, 10:28 PM
2001 Dodge Ram 1500
yeah... I erased the code by unhooking the battery, and then just put ~35 miles on it, and it didn't come back, I figured out it was the passenger side one... so II'm gonna replace it and see if that helps anything else (e.g. hard starts and rough idle)... We'll see... Thanks for the replies.
__________________
Old 01-26-2008, 02:53 AM
1997 Dodge Ram 1500
OK, just noticed your in California.
Therefore you should have 2 cat converters (one on each pipe from the engine) and 4 O2 sensors.
I think bank 2 sensor 2 is on the passenger side after the converter. Not 100% on which side but sensor 2 is definitely post Cat.
__________________
Old 01-26-2008, 09:54 AM
Parts/Service's Avatar
Parts/Service Parts/Service is offline
Vehicle: 1993 Ford Mustang LX 5.3
Bank 2 is the right side.......
__________________
Starting my 11th year as a Parts and Master Certified Service Manager. James O'Neal Dodge. Bremen GA.- 1-800-663-2522 www.onealdodge.com www.bigostreetrods.com
Old 01-26-2008, 10:52 AM
aim4squirrels's Avatar
aim4squirrels aim4squirrels is online now
2001 Dodge Ram 1500
Vehicle: 2001 Dodge Ram 1500 5.2L 2WD Reg Cab Long Bed
Quote:
ORIGINAL: SilverRam_01
O2 sensors don't affect hard starts or cold idle. The PCM doesn't read info from the pre-CAT O2 sensors until the engine reaches operating temperature and exits closed loop operation. The fuel mixture is high on cold idle warmup to heat up the engine quicker, and the O2 sensor would tell the PCM to lean out the mixture, causing a longer warmup period.
__________________
Old 01-26-2008, 10:55 PM
1997 Dodge Ram 1500
It's true it wont effect a cold start but these (OBD II) with heated O2 sensors can go into closed loop in under a minute. So well before your fully warmed up your O2 is trimming fuel.
__________________
Tags
01, 2001, check, code, codes, dodge, durango, engine, ii, intrepid, magnum, mil, obd, p0158, ram
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
