So after putting almost 100 miles on since the install, here are my observations. I'm sure some of the gains I'm seeing are caused by the fact that my plenum is no longer blown, and I fixed a bad cap and rotor. But even with that considered, there is a noticable gain in the mid RPM range over how the truck was before these other things occured. I don't have a tach, but if I had to guess, i'd say from 2000-4000 rpm range. It now takes very little throttle to get it moving at highway speeds in this RPM range. Accleration is so smooth too. I'm sure i'm going to see some nice results at the pump on the next tank I test f I keep my foot out of it. I'm definetly using much less throttle then I used to under normal throttle conditions. I have not perceived any low end loss at all (under 2000 rpm). It feels the same on the top as it used to except that now it pulls clear up to the shift points under hard acceleration. Before, it kinda ran out of juice before I got the full throttle shifts. I'd still like to see how it feels now when I tow, and under some other conditions.
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on Dodge Forums!
__________________
1999 Ram 1500, 5.2, 4x4, Fastman 50mm, Modded kegger, HS 1.7's, Edelbrock headers, Magnaflow cat, Flowmaster Super 40, B&G PCM, 4.56' s, Auburn LSD, 3" Skyjacker, 3" PA body, 35" Toyo M/T's, lots of other goodies. www.cardomain.com/ride/799288
Sponsored Links
Registered users do not see this ad. Click here to register for free!
I'll post this here because it could help with your DIY instructions: How does one tell if they have an EGR motor? I have a '96 5.9, and I've heard some do/some don't have EGR. What are we looking for - extra port on the intake with some contraption attached to it I'm guessing?
I kinda feel the same way you do. I think some of my gains were due to my plenum being repaired but I did feel a slight increase after 2500. I did the cut down when my truck only had an intake kit and a bored throttle body so I don't think I reaped all the benefits until I installed my exhuast system. The way the truck is set up now my powerband kicks in hard around 2700 or so without any noticeable loss of low end. You have a performance flash right? I really think that would help pull it together, along with 1.7s or a cam of course
__________________
01 Ext Cab 5.9 Off Road
Yeah, its modded
See 'My Garage' for details
what causes these trucks to cath fire im new to this whole dodge thing ive heard of this happenin on other dodge trucks and was wonderin what causes it before i start messin with mine
That was just cereal killer f'n with indy because indy left an oily rag in his engine bay that caused a fire.
__________________
Yeah, its modded
oh i got it now that i feel like a dumb*ss[sm=icon_beat.gif] but ive heard of these trucks catchin fire at the intake and burnin the aircleaner, harness and a whole bunch of other stuff gettin melted and thats waht i was askin about but ill be sure to make sure i dont leave old rags in the engine bay
You might want to take out the black lining on the underside of your hood if you go through alot of deep water. I've heard of it getting soaked falling down ontop of the engine and the exhaust manifold and catching fire.
__________________ 1996 Dodge Ram 1500 Sport 4X4
5.9 V-8
Yea i had that Lining catch fire on a Ford f-150, the battery shorted out on the fender and caught the damn hood on fire, Luckily i was able to put it out with a bottle of water
__________________
Daily Driver - 05 1500 Hemi quad cab, 3.92's, lsd in the rear, 17" Eagle alloy wheels wrapped with 295/70/17 Nitto terra grapplers, Superchips 3865, vararam intake,dynomax cat back, Synthetics all the way around
not only is it another possible way to do it, its the proper way. hope that tech certification means something in the end.
It means he can adjust his valves without setting his truck on fire
Lol.Damn,I think that was better then my joke.
__________________
1997 Dodge Ram 2WD Reg Cab Long Bed
5.2l Auto
Hypertech Power Programmer
Fastman TB
K&N CAI
Flowmaster 40 muffler Single In\ Dual out
MagnaFlow Hi Flow Cat 94037
180 tstat
Autolite Plugs
MSD Plug Wires 8.5mm, Napa Brass Cap, MSD 8228 Co
