I just used the little $10 breather in the ricer section at the auto store. and just made an adaptor to fit. (HA i used a LMI chemical injector off my service truck!!)
I used the APC breather that Advance sells in various colors. It just slides right into the 90 degree angle thing on the valve cover. I will get a picture. Hold on.
__________________
2001 Dodge Ram 1500 Offroad Edition with the 360.
Don't mind the blue wire loom. I would have rather used black probably but I had some blue in the garage I used on the Honda so I figured I minus well just use up what I had.
__________________
I used something similar to your blue breather, except mine is chrome and just pushes down into the valve cover. Gives it a nice old school look. Sorry, but no pics at this time.
My breather is a Spectre brand, bought at Advance Auto or Auto Zone.....forget which store it was. I have the part # written down at home but I am at work right now. I can post it later tonight when I get home. Here's the pic of it.
Hometheatherman, I see you have a 2001 I thought only the 1999 and earlier models can do the round air filter mod. Were did you get your tri-mesh screen foam filter??? How did you do your mod?????
I got it from Advance Auto but you might find it cheaper other places. It works fine idk what would be different about 01's and 99's. I did have a bracket custom made because I didn't like the cheapo one it came with. It's a Edlebrock Pro Flow air cleaner.
__________________
The kind of air cleaner I'm using you don't have to bend a S-Bolt thats only for the round style ones where the bolt needs to come through the top. The kind I'm using comes with a bracket you can easily bend with pliers maybe by hand. I found it flimsy and not wanting to stay bent like I wanted it to so I went to a local machine shop and had them make me one like I needed. They charged $30 and I don't think I could bend it if I wanted to without a lot of heat or a machine. It's really heavy duty and I like it much more.
Others have gotten the stock bracket to work though I just thought it was too flimsy.
__________________
