Like many other Ram owners who had this installed at the factory mine is falling apart. I called Napa and autozone and both said that they did not carry it and that only the dealer had those. I contacted the dealer and they said it would be ~$70. I got to wondering though if there is a similar aftermarket product that is better and at around the same price? I intend to replace it either way.
So does anyone know of other suppliers?
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad. Click here to register for free!
Vehicle: 2001 Dodge Ram 1500 5.2L 2WD Reg Cab Long Bed
RE: Replacement hood liner (the heat/noise shield)
I haven't found a stock replacement from anywhere except the dealer, but there are cheaper dealerships out there, and there are options like thermo-tec shielding that can be used: http://www.thermotec.com/product_detail.php?prd_id=16
Quote:
ORIGINAL: aim4squirrels
It is funny, I just ran across that company. I am having a bit of trouble figuring out which product would be appropriate (I had not even seen the product you linked to which specifically mentions hoods, I was looking at the Thermo-Guard FR). Besides being a bit prict (~$65ish for each 45x45 square) it would probably require a number of squares.
It makes me wonder if any of the auto body/detailing companies might know of something else sold in larger quantities.
Some dealership parts stores will sell things at different markups,
For instance, Huffines Dodge in Lewisville charged me $1.95 for intake mounting bolts and $0.45 for each plenum pan bolt which I believe was just above cost. The nearest dealership to me wanted 3.80 for each intake mounting bolt and $1.65 for each plenum pan bolt. Robbery! If you live in a large area, you can sometimes play one dealership against another, just make sure they aren't a part of the same ownership group.
Thanks for the info, will try that. Unfortunately there are about three, but they are all half an hour away. They want me to drive there to order it, then drive there to pick it up again, grr. Oh well.
Quote:
ORIGINAL: Silver_Dodge
My truck didn't come with one from the factory. Many didn't. If I where you, I would just tear it out and save the money for other mods or gas.
As I stated, I intend to replace it regardless. I had a 97 that just so happened to have the paint seperate from the hood at the exact spot that is hottest above the engine. It runs a good ~$300 to repaint it and I have no desire to risk that.
Do you really need it? I have an aftermarket hood on mine and never put the liner back on.Then again I still have primer on it because I havent had the truck painted yet.
__________________
1997 Dodge Ram 2WD Reg Cab Long Bed
5.2l Auto
Hypertech Power Programmer
Fastman TB
K&N CAI
Flowmaster 40 muffler Single In\ Dual out
MagnaFlow Hi Flow Cat 94037
180 tstat
Autolite Plugs
MSD Plug Wires 8.5mm, Napa Brass Cap, MSD 8228 Co
ya ive seen hood paint go white, then start peeling.it is funny you had brought this up, because i am doing mine.i am in the minths of doing alot of upgrades right now with my truck, i am very busy.
ok so this is what i am doing.i looked at dyna mat,heat shild,and some other comp. and they allareto much $.i dont know if you are familiar with duct work insulation, with the fiberglass and fire ret. backing,that is what i am useing.its nice and cromey(silver)
i took a 10x4 peice cut it to size,then with the side were the ins. is showing, i covered it with the scrap piece i cut off.i pulled the ins. off the scrap,so now both sides are silver with ins. in the middle,and taped up the seems with silver alum. tape. make sure you use as many clips as you can to reinstall, and now it is nice and bright so im going to dress it up with some dodge stickers (i would like a big ram head in the center.)
and thats what im doing.ill post pics when im done.
__________________
99 ext sport 5.9 4x4
315/70/16 MT mtz
f/m cat back
3' sus. lift
4 kc daylighters
rhino liner red
1 10' infinity 1052w w/infinity amp
1 ton rear wheel cyl
alum bezel,tint,180t-stat,8mm moroso wires
plenum fix and mod,castrol syntec oil
Quote:
ORIGINAL: mr freeze
I have dug through every post (this forum and others, Rams and others) I could and came to the following conclusions:
1) There is no authoritative post showing whether they have any effect
2) It is not clear if it exists for noise, heat, or both on Rams
3) TO me, it is worth spending $70 now for what could be useless rather than $300+ later.
