DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Trucks > Dodge Ram > 2nd Gen Ram
Thread Tools Search this Thread
Old 04-26-2008, 11:52 AM
RamTate RamTate is offline
Default RE: Identify a Plenum Leak
Quote:
ORIGINAL: Blaydrnnnr
heres another test.....( the PCV on my truck is passenger side... so... if yours is on the otherside.. just do the test as described..)
Take the vacuum hose off the passenger side of the intake that goes to your PCV... block it with a bolt or something... tape off or cap the port you just took it off of... now pull the breather hose that runs from your driver side valve cover to your airbox...off the air box...still connected to the valve cover...with the truck running..see if your getting a strong suction on the hose from the breather... if so.. its anothersign your plenum may be leaking... it was explained to me that the amount of suction here should be minimal.. or as it was put.. the vacuum should almost be neutral...You could take off the TB... ( about 15 minutes work...replace the gasket!!and a great chance to clean it and the sensors..) and get a better view of your plenum and intake.. I could actually see the blown gasket hanging inside.. mine was blown in three places...now... if your burning alot of oil... this doesnt mean your plenum is gone.. in fact.. you may have a bad blow-by problem which would mean oil getting blown into the intake past the valves I believe. I have been told thatheavy carbon build up could cause this... bad rings.... but... look at one thing at a time... check the plenum...mine was losing oil with nothing dripping on the ground.. and I couldnt see it burning in the exhaust....once I got the plenum off... it was no wonder. Let us know what you find!
Oh and I did this test before I took my TB off and that hose did not have any vacuume rather it was blowing...?
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Tags
2000, 59, blowing, breather, dakota, diesel, dodgedakotaupperplenum, ford, gasket, jpg, leak, oil, plenum, plunum, ram, tube, upper
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
