$130??? No way. Its a pain with the cold I suppose, but you can do it. If you've never done it before, it literally takes just a few hours, at absolute most. Took me about three my first time because I was extra careful and slow about which wire went where.
For the wires, I would buy some low-resistance units, but thats up to you. I elected for Autolite Professionals because, even though they weren't 8mm, they were the best wires I could find locally.
Take your time, go inside and warm up, come back out, do some of the work, go back inside, warm up, come back out, repeat.
My two cents. I wouldn't pay someone that much to do it, it isn't near as challenging as it seems.
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on Dodge Forums!
I need to do some serious maintnace on the truck this winter. I need to replace the cap+rotor, brake pads, coil, plug wires, valve cover gaskets, re-wire my lights, suspension bushings, trac bar, tranny fluid w/new cooler+deep pan, PCV valve, IAC sensor, oxygen sensors, re paint grille...the list goes on.! I think I have not done a oil change in 10,000 miles! This winter should be fun!
I just got to finish the S10!
Lets see my progress:
Cap+Rotor-Check
Brake Pads-Don't need replaced
Coil-Check
Plugs and Wires-Check
Valve cover Gaskets-No check
Lights-Still need to do
Suspension bushings-No funds
Track Bar-No funds
Tranny Fluid-No Check
Oxygen Sensors-No Check
Grille-No check
I'd stick with champion spark plugs, thats what dodge recommends. autolights work good in fords. I had autolights and it ****ed my engine up somethin fierce.
me too. my autolites work fine. sounds like installer error or something. and i am not debating if they are the best or not. im just saying sounds fishy.
__________________
SILVER TRUCK CLUB MEMBER #4 superchip 3815,52mm fastman,flexalite e-fan,k&n fipk,magnaflow,msd 8.5,autolite 3923's,accel coil,harland sharp 1.7rr's,cepek blacks and cepek 35 crushers,go rhino dominator 3 step ss,ss bull bar.
I also have the 3923 plugs in my truck and havent had an issue out of them yet. Now that school has started up I have racked almost 15,000 miles on those plugs. No issues so far
__________________
Mein Kampf- Yes, I have one of my own
If I agreed with you, we’d both be wrong.
