i used to have a single 4 foot on the left mirror and got a ton on interference (static) from the ignition system (damn gasoline engine, why cant you be a cummins)
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on Dodge Forums!
other than the plastic washer on the ant. mount where the ant goes through the bracket, though I actually think that might be my problem, because someone took my previous ant. off, and lost the original washer so i had to use one of those washer thigns that you get in some stacks of blank CD's. I got a new mount for my bumer though, once I get some money saved up Im getting a pc78 elite, some mini 8 coax, and a new ant mount.
There you go. I mounted my whip on my bumper this weekend and it works really well. the only thing I can say is be careful about how you use the plastic bumper cover. It just pops off with plastic clips. I broke off my outer clip and drilled my hole there so I didn't have to make a hole in my bumper. The mount I had went right through the hole no problem. But when I put the plastic cover on it took up most of my threads for my mount. So I suggest make a bigger hole in the plastic than just the screw.
__________________
1998 Ram 1500 4x4 360ci (5.9) flowmaster duals.Cobra 29wx cb 102" whip antenna Says it all.
My name is RAM and my tank is full, Till I have to go somewhere.
i got a 4 bolt mount that i just have to drill the holes for the mounting bolts. im actually gonna pick up a new ant. bolt as well as a spring, then later this week might go pick up some mini 8 coax
Vehicle: 1998 Dodge Ram 1500 4x4 5.9L 14x3 K&N Intake and Super 44 Flowmaster
my cb is broke...I think. If it isn't it is still good excuse to give the wife to buy a new one with the bluetooth feature for $169 (that models includes the weather channels)
__________________ TIMIDONE - 1998 Dodge Ram 1500 V8 5.9L 4WD: Mr.Gasket 14" Air Cleaner w/ K&N 14"x3" #1650 filter w/ Super44 Flowmaster Exhaust, BFGoodrich All Terrain T/A KO
/\ My New Toy! /\
