My truck was missing the check valve when I bought it, and I recently called a transmission shop about rebuilding the trans. When I told the mechanic that I wanted the check valve reinstalled, he told me my truck wouldn't drive without one as it aids the transmission in build pressure. He couldn't believe that I can drive my truck without one.
As a word of caution to you people wanting to remove the check valve, in colder weather, you're going to have to allow time for the truck to warm up as it won't want to move, especially in reverse, with the valve missing.
Hey squirrels, instead of hose clamps, why not have pressed on fittings instead, like power steering pumps?
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on Dodge Forums!
__________________
<< Insert long list of crap that's been purchased and bolted on to said vehicle here >>
Sponsored Links
Registered users do not see this ad. Click here to register for free!
I wont warranty any rebuild unless that check valve is removed. Its actually common practice to remove it. That check valve does not aid in building anything. It simply doents allow the fluid to drain back into the pan.
__________________
Professional Transmission Technician
86 Monte Carlo SS (waiting turbo buick swap)
84 Camaro z28 (ls1/t56 swap in progress)
92 Acura Integra (daily driver)
MonteC you are correct, The valve bodies, not OD units, are slightly different due to the H/E designation. I was tired last night. One (the E) is electronically controlled vs. a hydraulically controlled VB on the H. Sorry for the misinformation minis2003! I will fix that in the above post so future readers don't misquote bad info later on.
Eh. Close enough i guess. Youd need to take classes on the subject to get a better understanding i suppose.
__________________
hi montec its me again lol i did the trans tuneup and it went fine but now i have the same problem i had and also now it doesnt want to shift from 1st to 2nd unless i let off the gas and then press it again kinda like using a clutch to shift and then it shifts but the sometimes it seems like it drops back into 1st and so on if it goes right the first time for the most part the other gears seem to shift ok but when i hit passing gear it the tack jumps up and i go no where let off gas and im back where i started from let off gas in order to get it to shift could i have junk clogged in the check valve and can i just get rid of it with a piece of high pres hose thanks all for your input and help..
Refresh my memory, what all did you do again?
__________________
I wont warranty any rebuild unless that check valve is removed. Its actually common practice to remove it. That check valve does not aid in building anything. It simply doesn't allow the fluid to drain back into the pan.
Interesting. Thanks for the tip.
__________________
__________________
