DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Trucks > Dodge Ram > 2nd Gen Ram
2nd Gen Ram 1994 through 2001 Rams
Thread Tools Search this Thread
Old 02-11-2009, 12:16 AM
cdusthockey cdusthockey is offline
i talked to my friend who is a tech at a dodge dealer, and i was having the same problems as everyone is stating. i had very low heat at colder temps, but it seems fine once the outside temp rises above 20.
what he told me is to grab a hold of both of the heater core lines, the in and the out, if one is colder than the other your core is most likely pretty plugged. but like mine, both hoses were still too hot to grab a hold of for too long of a time.
he told me that if that was the case, the coolant was only flowing through a couple of the rungs of the core, causing both hoses to get hot, but not being able to throw enough heat.
he said that i can either bring it in and have it backflushed at a local place for around 70 bucks or if i felt like tackling it myself it shouldnt be too bad. he said to go to your local hardware or home depot like store and buy some LIME A WAY. first disconnect both hoses that go into the core and drain out and fluch out as much as possible with a hose then drain out as much as you can. then pour the lime a way in the core and let it sit for 20-30 min. once done rinse with hose again. if you feel like repeating by all means go ahead.
once finished just do your regular steps to fill the system all the way back up again
Good Luck
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
__________________
1999 Dodge Ram 1500
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 02-11-2009, 07:04 AM
dblj16380's Avatar
dblj16380 dblj16380 is offline
1999 Dodge Ram 1500
Vehicle: 1999 Dodge Ram 1500 4X4 5.9L V8
Quote:
Not to dis-credit your friend or anything but if you think about it, thats the way it should be.
A heater core is for all intents and purposes a miniature radiator. You flood it with hot coolant, use a fan to push air past it and warm up the air. This has to result in a temperature loss from the coolant. Therefore one line should be hotter than the other.
Now if it is a huge difference like one being ice cold and the other blazing hot, then yeah, you've got problems.
Old 02-11-2009, 04:14 PM
zman17's Avatar
zman17 zman17 is offline
2000 Dodge Ram 2500
The return hose should be only slightly cooler than the input, if the core is working properly. If they are both hot than it is clogged. Because, if only a couple tubes are clear, not only will you not have good heat, but the heat is resonating back through the return hose to the heater core. Due to the fact that there is not much flow.
__________________
2000 2500HD 4X4 5.9,SC3815, HS 1.7's,Borgeson shaft,
Fastman TB, Hughes Plate, 4x4 Posi-lok
Magnaflow Cat. w/Flowmaster 50 series, Rock Solid Ram Steering fix
Old 02-11-2009, 11:08 PM
dblj16380's Avatar
1999 Dodge Ram 1500
That's basically what I was trying to get at. Thanks zman for taking my jargon and re-wording/adding to it.
Tags
core, dodge, heater, ram
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
Vendor Directory
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
