Viper, what exactly did you use to mount those 500's behind the grille? I have a couple of 500's, and would like to put them on my truck, I just don't know what I need as far as a bracket of some sort. That, and if I see what you got, I could make something similar to it if need be.
__________________
1992 Ford Ranger XLT Extended cab 4X4 4.0 auto. Lots of mods, and still more to come.
1995 Dodge Ram 1500 SLT 4X4 318 5 speed single cab short box. The work horse.
I'm not going outside, but here is the approx specs on the brackets. They bolt right into the back side of the vertical member on either side of the radiator.
Quote:
Originally Posted by PurplDodge
I think I'm going to have a piece of flat stock welded to the side of the support (opposed to bolting the mount to the back of the support.
Why? Not only is bolting not permanent, it's way way cheaper, as well as adjustable.
__________________
Because I want it to be over-done. I don't want the lights to shake at all while driving down a dirt road.
Who said welding is permanent? Cut-off wheel and a grinder.
Adjustable? I can do it one time while I'm welding it.
Cheaper? My uncle has a welder. Also, it gives me an excuse to learn how to weld.
Mine don't shake at all.. The lights are mounted parallel to wide section of the steel. You'd have to have at least 1000lbs on the end of that to cause it to vibrate.
