DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Trucks > Dodge Ram > 2nd Gen Ram
Thread Tools Search this Thread
Old 02-21-2009, 12:01 PM
05DodgeRamHemi 05DodgeRamHemi is offline
Vehicle: 2005 Dodge Ram 1500 5.7L QC Sport
Send a message via AIM to 05DodgeRamHemi
Default Coolant Flush
I'm looking to get a coolant flush for my truck very soon. I've owned this truck for almost 2 years and I've never addressed the coolant system. Also, how often should a vehicle have a coolant flush? And, is this a job worthy of doing myself, or should I just have a shop do it?
If it is something worthy of doing myself, can anybody offer some steps I can take to make sure I do the coolant flush correctly? Thank You.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
__________________
2005 Dodge Ram 1500 Sport QC 5.7L Hemi
Flowmaster 40 Dual Exhaust, Toyo A/Ts, 20% Tint, Smoked Tail Lights+Headlights, Shorty Antenna, 8k HIDs
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 02-21-2009, 04:09 PM
Rex-TheDOGG's Avatar
Rex-TheDOGG Rex-TheDOGG is offline
1998 Dodge Ram 1500
Well, any job is worthy of doing yourself. The real question is, do you want to pay someone else to do a job you can do yourself.
If you have downloaded the 2001 FSM, take a look at it first before you start the job. If you haven't downloaded it yet, then please do so because it will answer a lot questions like "how often should a vehicle have a coolant flush?"
After the initial flush at 52,500 miles (Sched. A), Chrysler recommends changes every 30,000 miles so you are probably past due. If you do it yourself, then you have to contend with disposing the old coolant. In my area, we are allowed to flush it down the commode because our waste water treatment system can handle anything that's in the coolant. I don't know what the regs are in Maine. If you do it yourself, then I would remove the thermostat and back flush the block and radiator seperately from the heater core, then back-flush the heater core with very low pressure water. It's not that hard to do. But if you don't want to fool with it, then there is nothing wrong with paying a shop do it.
As for coolant, there is the tried and true green stuff and the orange stuff (Dexcool). There has been some issues with Dexcool eating the old style composition head gaskets, so I would recommend getting the green stuff. Probably cheaper anyway.
__________________
98 Ram 1500 QC 5.9L, 2WD, Hughes heads and cam, 52mm Fastman, B&G reflash, 180 t-stat, Edelbrock shorties, Magnaflow cat, and Flowmaster 50HD
Old 02-21-2009, 04:30 PM
Ram2K1's Avatar
Ram2K1 Ram2K1 is offline
Vehicle: 2001 Dodge Ram 1500 QC 4x4, 5.9L Auto
Advance sells 5 yr/150K mile coolant, so I would suggest that...and a tester is a good investment. That way, you can just see if it's still good before doing a flush. I've seen some people who do it every year, but I think that's overkill. It all depends on what you want to do...if you have the time. Personally, when it comes to that stuff I don't really trust shops. Maybe I'm too paranoid, but there are a lot of shady places out there.
__________________
Tim
2001 SLT QCSB 4x4, 5.9L Slushbox
-Saved by Grace through Faith-
Old 02-21-2009, 05:11 PM
dakotas ram's Avatar
dakotas ram dakotas ram is online now
1978 Ford F-100
Vehicle: 95 ram
dont forget, right under your heads there are drain plugs too if you want to take them out and get a little better flush........they also sell coolant flush that you run for a few days to break everything up
__________________
Old 02-21-2009, 05:33 PM
zman17's Avatar
zman17 zman17 is offline
1998 Dodge Ram 1500
I wouldn't use any type of cleaner that breaks any thing up. You'll wind up clogging the heater core. If you want to just change the fluid, use the drain plug on the radiator or remove the lower hose to drain. And replace with new fluid and be done with it. But on the other hand, if it ain't broke don't fix it.
__________________
98 1500 4X4 5.2,SC3815, HS 1.7's,Borgeson shaft,
Fastman TB, Hughes Plate, 4x4 Posi-lok
Magnaflow Cat. w/Flowmaster 50 series, Rock Solid Ram Steering fix
Old 02-21-2009, 05:52 PM
IndyRamMan IndyRamMan is offline
I wouldnt do it yourself, because at this point...2 years into it....you havent learned one iota of advice anyone has given you and you probably havent bought a wrench or even a screw driver in that time...stick with the shops its what you do.
__________________
14.40 @ 96, 2.21 60' - Open rear, Cam, Indy Truck
14.31 @ 97.5 2.10 60' - Street 225 tire, 3.73, Mustang
Old 02-21-2009, 06:10 PM
zman17's Avatar
1998 Dodge Ram 1500
+1, I just didn't want to go there. That's why I said if it ain't broke don't fix it! It's like you just look for problems.
__________________
Old 02-21-2009, 06:41 PM
1978 Ford F-100
Vehicle: 95 ram
he did say coolant FLUSH, not change, which would be to remove any deposits and such
__________________
Old 02-21-2009, 07:10 PM
zman17's Avatar
1998 Dodge Ram 1500
Whatever! This kid has a way of making a mountain out of a mole hill. He will pay some one to flush the system, then there will be no heat or something.
__________________
Old 02-21-2009, 07:46 PM
If we could please be adults here and eliminate the erroneous attacks, it'd be much appreciated. I am opening my ears to those who are here to help me, not criticize me. And for the record; I do have tools. I purchased a sears 283 piece tool set last fall, and have done several jobs with it.
Rex-TheDOGG, would you be willing to provide a little more step by step instructions how to do this? Thank You
__________________
Tags
1500, 1998, backflush, change, coolant, cooling, dodge, flush, neon, radiator, ram, sistem, stratus, system, viper
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
