Hello,i brought my truck in for a alignment the other day when i returned to pick it up they said i had alot of negative camber causing the tires to slant in towards the truck, they said if i wanted to get the camber correct i had to buy (camber) adjustable ball joints, but they want $320.00 for the parts and $420.00 for the labour, why is my camber off? I do have a 2.5 inch levelling kit and 285/75/16 tires is the extra height in the front causing the negative camber? Will this affect your ride at all either...your advice would be greatly appreciated.
Thankyou
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad. Click here to register for free!
A leveling kit won't affect 4x4 alignment ... well ... maybe caster ... by a hair.
__________________
Silver Truck Club member #26
98 1500 4x4 SLT Laramie Quad 5.9L Auto 3.55 LSD 285/75R16 BFG AT T/A KO DT PROFAB Adjustable Trac Bar MP PCM Crossdrilled/slotted rotors GM 1-ton brake mod
Reason: Posted pic
Camber can be adjusted on a 4x2 , so it's a 4x4. When a 4x4 has neg. camber there is a problem with the axle. The tubes can be bent, or the mounts where the steering knuckle connects to the axle (where the BJ's go)have collapsed. (The top one is bent inwards). This is usually from some major abuse. It is a known problem, which is why they make the adjustable joints.
Mine's been that way since the day I bought it ... new.
__________________
__________________
Man ... you just came up with a COOL concept ... a towing race at Daytona. 43 (real) trucks with a camper on the tail.
__________________
