DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Trucks > Dodge Ram > 2nd Gen Ram
Thread Tools Search this Thread
Old 03-24-2009, 05:00 PM
livinterror livinterror is offline
Default towing
What are the towing specs on a 97 ram 2500 4wd? I have a 5th wheel hitch also. Whats the most I can pull safely? Also what can I pull with the towing package? Thanks
I just need the weight ratings
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 03-24-2009, 05:48 PM
Cereal Killer's Avatar
Cereal Killer Cereal Killer is offline
What motor is in it? V8, V-10, I-6?
__________________
1996 Dodge Ram 1500 Sport 4X4
5.9 V-8
Old 03-24-2009, 06:40 PM
zman17's Avatar
zman17 zman17 is online now
1998 Dodge Ram 1500
I don't know, but I'm sure CK will help you out when you give him the info he asked for.
However, the one thing I do know,(if it's an automatics trans) is that if you are doing some serious towing, you should replace the factory trans cooler with a better aftermarket cooler. And never tow with OD on.
__________________
98 1500 4X4 5.2,SC3815, HS 1.7's,Borgeson shaft,
Fastman TB, Hughes Plate, 4x4 Posi-lok
Magnaflow Cat. w/Flowmaster 50 series, Rock Solid Ram Steering fix
Old 03-24-2009, 07:13 PM
Oops. I forgot to put the engine size. I guess that would help! Its a 5.9. Auto tranny. I have done plenty of towing with it across the US with several 5th trailers but I would like to know the most it can tow.. The biggest I ever towed was a 30ft 5 wheel. I now have a 27 1/2 ft 5th wheel.. thanks
Old 03-24-2009, 07:16 PM
Also the 5th wheels I have towed before were right around 7,000 pounds. The truck does great! Truck stops very good and you don't even know the trailer is back there unless there's a strong cross wind...
Old 03-24-2009, 07:22 PM
zman17's Avatar
1998 Dodge Ram 1500
Well, not using OD, and beefing up the tranny cooler will just help with the life of the tranny. But, seems you are doing fine so far. Sorry I can't help with the towing capacity.
__________________
Old 03-24-2009, 07:26 PM
PurplDodge's Avatar
PurplDodge PurplDodge is offline
1999 Chevrolet S-10
My Garage
Vehicle: Dont drive....
Quote:
5.9 Cummins or 5.9 V8? I have a 25ft camper, but have not towed it yet.
__________________
My name is Nathan and my tank is full
Oil Change DIY Plenum Gasket Repair FAQ
Old 03-24-2009, 10:02 PM
Assuming you mean 5.9 V8 I think it's between 8600-8800 pounds although with a 5th wheel I'm sure it's a bit more than that. Now if you're meant a 5.9 I6 (12v) then it's more like 13,000lbs and you are a bastard =p
I know you can tow heavier with a 5th wheel, but i'm not sure how much. If you're pushing the limits of that you should take care to beef up your brakes, and get yourself a super sized tranny oil cooler.
__________________
5.9 V-8
Old 03-24-2009, 11:06 PM
5.9 gas. I wish it was a diesel. The towing I do is right around 7,000 pounds. So I am not over weight. Truck stops great and pulls it great. I have pulled numerous trailers. I am just wondering what the weight limits are?? I also have a lift on the truck and some bigger tires etc etc
Thanks again
Old 03-24-2009, 11:13 PM
Yeah, you'll be absolutley fine with 7,000lbs. You still might want to consider getting yourself a big beefy Tranny oil cooler, even if you have the stock one. Just cut the return line from the stock cooler, and run it into the bottom of the new cooler, then run a new hose from the output of the original to the input on the new cooler. It'll let you fit a little extra fluid too which is really good. It's an inexpensive mod. and you'll need a $3.00 fuel line disconnect tool.
I say this because you have a 46re and they kinda suck.
__________________
5.9 V-8
Tags
1500, 1996, 1999, 2500, 59v8, beefing, caravan, dodge, httpwwwyoutubecomwatchvo8houmeilu, ram, rating, suspension, tow, towing, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
