DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Trucks > Dodge Ram > 2nd Gen Ram
Thread Tools Search this Thread
Old 03-26-2009, 09:45 PM
geggle geggle is offline
Default V10 Oil Pump Replacement
Okay, I think I have no choice but to replace the oil pump on my 2001 2500 V10. Idle pressure cold @ 12lbs. Pressure cold at 3000rpm maybe 25lbs. I've exhausted all other possibilities.
Question is, D I need to remove radiator to access the timing cover? A chilton book was rather vague on this. I wouldn't mind doing it if necesssary but the are alot of transmission lines, ac lines, etc attached to it. And I really don't know how to disconnect them. I looked, but I can't figure some of them out. (Chiton just said "Disconnect").....Duh?! they didn't say how the connections worked.
Can anyone help on this? Please someone tell me that it can be done without removing the radiator...........Please!
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 03-29-2009, 02:52 AM
Default Update
Turns out, it can be done without radiator removal. But, I thought that this other bit of info may be helpful to some others.
After getting to the oil pump I discovered that 3 of the 5 torque screws holding the rear pump cover had backed out. One was about 3/16s out. This allowed alot of oil to pour into the timing cover and right into the oil pan. I haven't put it back together yet (still waiting for the new pump and gaskets. But I'll bet you that I could put the old rotors back in, button her up, and have twice the oil pressure that I was showing. But as long as I'm already in there..............
Anyone else ever heard of this happening? I'm glad I found some cause for it. And I'm glad I caught it in time. There is no evidence of any damage. And I'm certain there would have been a seized engine in my not too distant future. All because of a few .50 screws.
Moral of the story is........... lots of Loctite!
Old 03-29-2009, 04:49 PM
This is exactly how it was when removed. Screws to both sides of the worse one are backed off also (tho not as much). Hope I get this picture rightIMG_1355.jpg
Old 03-29-2009, 08:48 PM
Gotta feed them horses Gotta feed them horses is offline
Vehicle: 1996 Dodge Ram 2500 V10
the same thing happened on my v10 about 3 years ago. i had no idea why the pressure was low (25ish) and my uncle looked at it for about 15 mins and he figured it out and since then the pressure has stayed at 45 psi.
Old 03-30-2009, 12:15 AM
Yeah, I wondered if this happened to anyone else. I'm gonna loctite the snot out of the screws and then I'll probably "Ping" the edges. I ordered a new rotor kit prior to tearing into it. That and the gaskets won't be in until Tues. (here in Montana no one cares any inventory). In all honesty, I don't think there's anything wrong with the old rotors, but better safe than sorry. And I'm already in there.
Could have been a disaster though
Old 03-31-2009, 10:29 PM
Truck back together now. Had to use old pump rotors after all (Backordered). Pressure now about 48 at idle and 68 at 3000rpm. Much better
Old 07-25-2009, 11:37 AM
darrelldellinger@bellsouth.net darrelldellinger@bellsouth.net is offline
Default 1995 v10 dodge 3500
i have a 1995 dodge 3500 v10 no oil pressure does both rotor gears turn in the housing or not i have been told yes and no so please help thank darrell
Old 07-25-2009, 11:47 AM
zman17's Avatar
zman17 zman17 is offline
1998 Dodge Ram 1500
I don't know anything about a v10 oil pump other than it is part of the timing chain cover, and a rotor wouldn't be called a rotor if it didn't rotate.
__________________
98 1500 4X4 5.2,SC3815, HS 1.7's,Borgeson shaft,
Fastman TB, Hughes Plate, 4x4 Posi-lok
Magnaflow Cat. w/Flowmaster 50 series, Rock Solid Ram Steering fix
Tags
2500, change, dealer, dodge, ford, grade, kit, low, moparts, oil, pressure, pump, ram, truck, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
