How can i fix this? It can be something so easy as my gas cap not sealing right. My truck is getting 9 MPG. I need this fixed..any ideas on what this can be...anyone else have this problem? Please Help. And its causing my check engine light to be on and i cant get my inspection done. CRAP. HELP PLEASE!!
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on Dodge Forums!
__________________
2001 RAM 5.9 V8 OFF-ROAD EDITION. NO MUFFLER, SMASHED ON A ROCK WHILE MUDDING!! 285/75/16 NITTOS AT. HELD UP BY DUCT TAPE
Sponsored Links
Registered users do not see this ad. Click here to register for free!
So, your getting a P0441 engine code, which is a bad purge flow?
Check to make sure all your hoses are attached to the canister.
Also, If you have switched to a locking gas cap, make sure it has vents.
That was my issue, I started to get that code shortly after I went to that locking cap.
The code went away when I switched back to the stock cap.
__________________
Mein Kampf- Yes, I have one of my own
Is now creating sigs Look
Red Truck Club Number 7
To vote in polls
1. Member for 30 days
2. 50 or more posts!
i had that evap system leak problem on my 01. Wasn't the gas cap go figure. Took it to my local shop and they were able to put it on a smoke machine and find the leak. One small hose leak was the issue. this could be a better option then to just start replacing hoses. Good luck.
When I got that code on my 97 1500, I changed the purge solenoid and the charcoal canister. Cost me 80 bucks. Hope that helps.
I had several cracks in my hoses when I had this code...
The small hoses near the purge solenoid, and the big meaty fooker on the evap canister. My hoses were destroyed! I've never seen a hose look so bad - but $11 at the local parts store and it was fixed. The stealer wanted 90 bucks for the pre formed hoses... uh, no thank you!
