DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Trucks > Dodge Ram > 2nd Gen Ram
Thread Tools Search this Thread
Old 04-07-2009, 05:39 PM
nakw nakw is offline
Vehicle: '99 Ram 1500 5.2L V8 2WD
Question Pot Hole and Uncontrollable Rocking
I was driving home on the freeway going about 60 when I hit this pot whole that spanned the entire lane. Upon hitting it the truck did the usual lurch, nothing unusual, but then it started rocking back and forth uncontrollably, as if I were going over super bumpy asphalt, but seeing as I was on a newly paved road, it wasn't the road, it was the truck. I instinctively checked all my gauges but they were all normal, so not knowing what to do I pressed on the brake. As my speed decreased the rocking slowed and at around 40mph it stopped and the truck ran fine the rest of the way home. So what in the hell caused that? It lasted maybe 20sec but made me feel as if my truck was gonna fall apart under me. Could it be the alignment or something? Any help would be appreciated.
My truck's a '99 Club Cab 5.2L V8 with no mods.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 04-07-2009, 05:48 PM
zman17's Avatar
zman17 zman17 is online now
1998 Dodge Ram 1500
Assuming you have a 4x4! Check the Trac-bar . Also do a search on here for Death Wobble.
__________________
98 1500 4X4 5.2,SC3815, HS 1.7's,Borgeson shaft,
Fastman TB, Hughes Plate, 4x4 Posi-lok
Magnaflow Cat. w/Flowmaster 50 series, Rock Solid Ram Steering fix
Old 04-07-2009, 06:04 PM
dodgeram32's Avatar
dodgeram32 dodgeram32 is offline
Vehicle: 99 Dodge Ram 5.9 360, dual flowmaster's,Poweraid TBS, westin push bar,285/75/16 a/t's
+ 1 on trac bar
__________________
Old 04-07-2009, 06:07 PM
My trucks not a 4X4 though. . . thanks for the fast replies!
Old 04-07-2009, 06:35 PM
zman17's Avatar
1998 Dodge Ram 1500
Well first of all, that's a bit of info you should provide in your sig, don't you think?
And second, describe "rocking back and forth". Obviously I mis read that and assumed you meant the steering wheel was shaking.
__________________
Old 04-07-2009, 06:43 PM
I do need to work on a sig =P
The entire truck was shaking violently. To the point where when I looked into the rearview mirror it was so distorted with movement that I couldn't make out whether there was a car behind me or not. It was as if the truck was going to vibrate itself apart. The steering wheel was indeed shaking, as was everything else, however. It was as if the lurch that I got from going through the pot hole continued to happen over and over again as I continued driving. You know that feeling, when the truck bounces about rapidly after going through a pot hole at a fast speed? It was like that but for a 20sec duration on a newly paved road.
Old 04-07-2009, 07:13 PM
zman17's Avatar
1998 Dodge Ram 1500
It is indeed a death wobble, but some 2 wheel guys will have to chime in here. IMO, the first thing you need to do is get another person and have them turn the steering wheel left to right, while you look underneath (without the truck running) and see if any steering parts are loose. Then raise the front off the ground and grab the tire at 6 and 12 o'clock and see if anything is loose,(wheel bearings, ball joints). Also grab at 3 and 9 o'clock and push front to back to see if the control arm bushing's are shot.
__________________
Old 04-07-2009, 08:19 PM
Viper37 Viper37 is offline
A Hawaii truck wont have corrosion issues like the snow guys here, but it's possible due to the sea air. Check your body mounts.
Does the shaking come from the front or the rear of the truck? Just knowing that will help a lot.
Old 04-07-2009, 08:39 PM
Thanks for the tips Zman17, I'll try that out later today. I do live right up the street from the beach, so that would cause some corrosion. I'll check my body mounts while I'm at it, Viper37, thanks for the tip.
It seemed like the shaking could have been originating from the front of the truck, as the cab was shaking madly and the brunt of the impact with the pothole was taken by the front. Thanks again for all the replies!
Old 04-07-2009, 08:49 PM
Jack up the front end, give each of the tires a nice love kick, make sure your ball joints aren't shot. Examine your bushings and make sure they are all there. (some cracking is ok, but if there are chucks missing that is a problem) Basically go through your front suspension and make sure nothing isn't moving how it shouldn't.
Also, while you are at it... Check your motor mounts.
Tags
2008, 3500, cab, cummins, dodge, driving, pothole, potholes, ram, rocking, shakes, shaking, truck, uncontrollable, vibration
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
