DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Trucks > Dodge Ram > 2nd Gen Ram
Thread Tools Search this Thread
Old 04-23-2009, 10:01 PM
atc250r atc250r is offline
Vehicle: 1997 Ram 1500 c/c 4x4
Mopar99, I have the same problem as you. My pressure remained steady all the time, then about 10,000 miles ago it started fluctuating with temp and rpm. Interested to hear solutions as this problem concerns me, too.
Anyone know how costly and difficult it is to change a pump???
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 04-23-2009, 10:15 PM
Budb77 Budb77 is offline
1999 Dodge Ram 1500
Vehicle: 1999 Dodge Ram 1500 Sport 5.9L V8 (stock except for a 40 series two chamber exhaust)
oil pump when i replaced it through chrysler i think i paid about 140 to a 160 dollars for me at my dads cost and thats the good mopar brand but it was also for a 5.9L V8 and really easy to change drop oil pan its like three or four bolts and it drops out very easy installation
Old 04-23-2009, 10:18 PM
dodge15004x45.9 dodge15004x45.9 is offline
2001 Dodge Ram 1500
Vehicle: Ram 1500 4x4 5.9 auto reg cab 8ft bed Cherry bomb muffler k&n intake.
Send a message via AIM to dodge15004x45.9 Send a message via Yahoo to dodge15004x45.9 Send a message via Skype™ to dodge15004x45.9
Quote:
Originally Posted by dakotas ram View Post
mine is about 50 cold, then 45ish from then on out......ive heard that a clogged pickup screen can make your symptoms....
Would seafoam fix it?
__________________
01 ram 1500, 4x4, 5.9, 3" top guns customz lift. PA truck club join here>http://dodgeforum.com/forum/dodgefor...ruck-club.html
Old 05-02-2009, 06:24 PM
mopar99's Avatar
mopar99 mopar99 is offline
Vehicle: 98 neon
Default oil pessure
thanks my truck has only 98000 miles so im going to run some engine flush through the motor then im going to just replace the pump with a standard melling pump not the high volume one. i will let you know if that solves the problem.
__________________
98 Neon; CAI, MTX Conversion, Pacesetter Header, Glasspack Exhaust, Rear Disc Conversion Plus Sway Bar
99 Ram 1500; CAI, Flowmaster
03 Yamaha R6; Micron Exhaust
Old 05-03-2009, 10:21 AM
charlie1935's Avatar
charlie1935 charlie1935 is offline
Vehicle: 96 Ram standard cab, short bed, 318 auto. tranny. 87 D100, long bed, 318 auto. 87 5th Ave. 318.
Quote:
That much for an oil pump?
I hope you got a kiss too!
__________________
Grandpas like toys too
Old 05-03-2009, 12:48 PM
1999 Dodge Ram 1500
oh yeah they cracked me hard on that one for the pump alot of it was cuz these small places like autozone and advance where two weeks out and i couldnt wait so chrysler gave it to me hard
Old 05-03-2009, 06:50 PM
dhvaughan's Avatar
dhvaughan dhvaughan is offline
Vehicle: 01 1500 4wd
Quote:
a little more trouble than it should be.
here's a good article from pavement.
i replaced my oil pump and rear seal a couple of years ago.
the hardest part was getting the damn starter off.
it seems like you should be able to get the oil pan off w/o removing the inspection cover and starter, but i was unable to do so.
i did not have to drop the exhaust, nor raise the engine like haynes manual says.
http://www.pavementsucks.com/tech/rearmain.php
__________________
01 1500 Reg Cab 4wd 5.2 auto 3.55 285/75/16 nasta step bar tow hook sc3815 180 3923 trans cooler/filter posi-lok powertrax noslip timbren brite-box pioneer head rockford amp/speaker cobra cb firestick hughes plenum water pump timing chain oil pump rear seal front bearings brakes shocks cracked dash towing composting boat.
Tags
1997, 2500, 340, 59, cummins, dodge, drops, load, low, mopar, oil, pressure, ram, warm, warmed
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
