DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Trucks > Dodge Ram > 2nd Gen Ram
Thread Tools Search this Thread
Old 05-10-2009, 10:29 AM
dodge6 dodge6 is offline
Default IAC OEM numbers for 1997 Ram...wacky idle
I have some problems that seem related to the IAC on a 1997 Ram 5.9L.
I replaced a bad IAC with an after market years ago and kept the original. Its OEM 53030657.
I went to the dealer this time and using VIN was given OEM 53032067AA.
Using intechanges and a Mopar parts sight, it looks like my original is replaced with same number with AC suffix, and part I recieved is for newer model 8L engine. Does anyone know if its right part or if it really matters that much?
Dealer said what I got was correct for my VIN and replaces my old number.
Any ideas?, thanks
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 05-10-2009, 10:35 AM
dhvaughan's Avatar
dhvaughan dhvaughan is offline
Vehicle: 01 1500 4wd
i suspect its right. the IAC and TPS are common parts, shared by lots of different models, engines, and years. part numbers change all the time. just by the way, I had a strange surging idle and after replacing IAC several times with varying results I replaced TPS and problem was solved.
__________________
01 1500 Reg Cab 4wd 5.2 auto 3.55 285/75/16 nasta step bar tow hook sc3815 180 3923 trans cooler/filter posi-lok powertrax noslip timbren brite-box pioneer head rockford amp/speaker cobra cb firestick hughes plenum water pump timing chain oil pump rear seal front bearings brakes shocks cracked dash towing composting boat.
Old 05-10-2009, 10:39 AM
zman17's Avatar
zman17 zman17 is offline
1998 Dodge Ram 1500
It's probably right, and I don't know what year 8.0 you say it also fits , but where ever I look different part #'s come up.
__________________
98 1500 4X4 5.2,SC3815, HS 1.7's,Borgeson shaft,
Fastman TB, Hughes Plate, 4x4 Posi-lok
Magnaflow Cat. w/Flowmaster 50 series, Rock Solid Ram Steering fix
Old 05-10-2009, 11:40 AM
I looked on Mopar parts sites and it shows the part I got is for 2000-2003 8.0L Dodges and my old number for 5.9L or all models w/o 8L. Original number ending in AC I think was for upto 2000-2001 models but again w/o 8L. Just wondering if this is contributing to my problems.
Old 05-10-2009, 11:49 AM
zman17's Avatar
1998 Dodge Ram 1500
Parts are always getting # changes, they redesign parts to work on more than one application, it is cheaper for them that way. But , like DV said, it might not even be the prob, it could be the TPS. Maybe others will chime in if you describe in more detail what probs. you are having
__________________
Old 05-10-2009, 09:46 PM
The real problem is similar to other posts I've seen, but I haven't come across a fix for mine yet. Been doing this a few years but seems more frequent now. Truck starts fine, idles good. If left idling after start up, usually within 2 minutes or less, the engine starts idling rough and makes hissing sound thru intake. A light tap of the gas will clear it up, if left alone it will clear its self after up to 30-45 sec, usually with a quick jump in idle speed and then returns to normal. Does it with cold or warm start. I have an Auto XRay scanner that shows the IAC stepping up and vacuum dropping and then usually misfires on cylinders. No codes are set.
What's been done: cleaned throttle body, new IAC, TPS, cam sensor, crank sensor, MAP sensor, coil, wires, plugs, cap, rotor, reroute wires, new evap solenoid(was stuck). New Magnaflo Cat, Flowmaster exhaust. Chg'd crank sensor when changing cat because it was easy to reach with cat out. These parts have been done at different times but all are fairly new. Intake didn't seem to have any pooled oil, and coolant temp reading seemed ok does differ about 10 deg from dash gage. So everythings about new, truck runs great otherwise and I'll continue to live with it if I can't track it down.
Guys got any other ideas I can try?
Old 08-04-2009, 10:28 PM
mr.318 mr.318 is offline
I was just doing a search and read this post, Did you ever fix your truck mine dose the same thing, And when i got my I.A.C it looks like the pintle in it, was shorter.MIne dose the hissing to
Tags
1500, 53030657, 97, caravan, dodge, iac, number, oem, original, part, pcm, position, problem, ram, sensor, throttle
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
