My case has a slow leak mostly coming from where the two pieces of the main case come together from what I can tell. Has anyone else had this? Any advice on sealants and procedure?
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on Dodge Forums!
__________________
1999 Dodge Ram 1500 4x4 5.9 Auto , Flowmaster Cat, clear front headlight lenses, drilled slotted rotors, Clarion head, Infinity Kappas front and back+ Infinity Amp and 10" subwoofer.
Sponsored Links
Registered users do not see this ad. Click here to register for free!
are you positive that its your transfer case and not your transmissions rear seal? mine leaks and it looks like its coming from the transfer case but its not. lol if it was your transfer case, you would have to take your truck to a lift (easiest way) and spend a few hours taking it out. then you'd have to crack it open, put some new gaskets on and stuff...check to make sure everything inside is good and slap it all back together. i swapped out transfer cases in my truck when i first got it, and it took me and a friend that had never done it before about 5 hours lol
have you tried re-torqueing the bolts? they may have just worked loose. torque them, clean it up and see if it still leaks. also make sure there are no cracks in the case.
__________________
I'm sorry, I can't hear you over the sound of how awesome I am.
You need to find exactly where the leak is coming from. Mine looks like they over torqued the bolts that hold the two halves together. There are little spider cracks on the bottom. I just wiped it clean, dried it, smeared some silicone on it and it stopped the leak. That's been 140,000 miles now. I just have to redo it every time it is in the shop cause the shop guys see it and scrape it off.
The mating surface between the trans and transfer case is not a sealing surface. There is a tranny rear main seal, and a transfer case input shaft seal. Both ride on the transfer case input shaft. The input shaft slides onto the splines on the trans output shaft and fills the void between the output shaft and the trans seal. Pull the TC and change 'em both. The TC seal housing unbolts from the front of the TC, the trans seal just slides in. IIRC, there's no stop lip on the trans for the seal, so don't drive it in too far....
__________________
98 ram 1500, 318, pretty stock, seems to be continually dirty....
i believe he's talking about the two halves of the transfer case housing leaking.
__________________
