DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Trucks > Dodge Ram > 2nd Gen Ram
2nd Gen Ram 1994 through 2001 Rams
Thread Tools Search this Thread
Old 07-01-2009, 12:49 PM
tj1320 tj1320 is offline
Default Three Codes: P0300, P0302, P0331
I need help with the following codes if you guys can:
P0300 - Random/Multiple Cylinder Misfire Detected
P0302 - Cylinder 2 Misfire Detected
P0331 - Knock Sensor 2 Circuit Range/Performance (Bank 2)
Any idea as to where to start the troubleshooting? The plugs are Autolite 3923s with 4,000 miles on them and the wires are MSDs with 13,000 miles on them. The cap, rotor, and Accel coil are all pretty much new with 13,000 miles on them as well. I'm not sure what else to look at at this point. The problem is with the truck in my sig.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
__________________
'98 Ram 4x4 QC 5.9L 46RE
Summit Racing CAI
Gibson split cat-back
MSD 8.5mm wires
Accel coil
SCT Tuner
Pacesetter Long Tube Headers
Off-road y-pipe
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 07-01-2009, 04:19 PM
zman17's Avatar
zman17 zman17 is offline
2000 Dodge Ram 2500
I would start by checking the plenum and the cat. If you have a cat.
__________________
2000 2500HD 4X4 5.9,SC3815, HS 1.7's,Borgeson shaft,
Fastman TB, Hughes Plate, 4x4 Posi-lok
Magnaflow Cat. w/Flowmaster 50 series, Rock Solid Ram Steering fix
Old 07-01-2009, 04:26 PM
No cat and the plenum repair was done a few months ago. I'll check again though just to make sure the repair didn't fail.
__________________
Summit Racing CAI
MSD 8.5mm wires
Accel coil
SCT Tuner
Off-road y-pipe
Old 07-01-2009, 05:07 PM
zman17's Avatar
2000 Dodge Ram 2500
If the plenum appears ok, then check fuel pressure while driving also, by taping the gauge to the wiper arm or windshield so you can see it. Then the crank or cam position sensors would be next on the list. Check the wiring and connectors to them first though. And if you don't have a pinging problem I would toss the Autolites (atleast check them) and put Champions or the NGK's Aim recommends.
__________________
Old 07-02-2009, 06:03 PM
Thanks for the help. So whats the deal with the Autolites? I have never seen a negative post about them before yours above.
__________________
Summit Racing CAI
MSD 8.5mm wires
Accel coil
SCT Tuner
Off-road y-pipe
Old 07-02-2009, 06:52 PM
jasonw's Avatar
jasonw jasonw is offline
2nd Gen Ram & PC Help
Dodge Forum Moderator
2001 Dodge Ram 1500
Vehicle: 2001 Dodge Ram 1500 4x4 QC
Send a message via Yahoo to jasonw
In some cases, they make the truck run slightly rough, and in a very few severe cases, I've read of them causing misfires.
I currently run them and am experiencing a very slight rough idle. I used to need them when my plenum gasket was broken (pinging), but now that that is fixed, I will be grabbing the NGK V-powers for my next change, see how they do.
__________________
5.9L 360ci Magnum V8
Single 3" Flowmaster Super 44 Exhaust w/ Magnaflow Catalytic Converter
Volant Cold Air Intake Kit
Fastman 52mm Throttle Body
Modified Intake Manifold w/ Hughes Plenum Reinforcement Kit
SCT XCalibrator 2 Tuning by Hemifever
Awaiting Install: 3.92 gearing all around & Auburn LSD in rear axle
Solutions to Common 2nd Generation Dodge Ram Problems
Old 07-07-2009, 12:04 PM
Hmm, I guess that could explain it.
I talked to my mechanic buddy, who talked to his Chrysler mechanic buddy, who said that it could be a crack in the heads. Apparently, when the truck is used to just hauling around its own weight all the time and you load it down with a heavy trailer, this will happen. That makes sense to me because I had no issues at all prior to pulling that trailer. I noticed the initial problem up a hill while pulling that trailer. I was only driving 65 MPH (OD off) but I noticed a couple sudden, fairly "stout" misses and then it ran fine from that point on. By "fine", I mean that I didn't notice the rough idle problem until the truck was idling at a traffic light the next day. I hope it isn't the heads but I guess I could use this opportunity for some higher flowing heads.
__________________
Summit Racing CAI
MSD 8.5mm wires
Accel coil
SCT Tuner
Off-road y-pipe
Old 07-07-2009, 12:24 PM
VWandDodge's Avatar
VWandDodge VWandDodge is online now
Vehicle: 1997 Ram 1500 4x2
Quote:
You must not read much. I've posted several times that my truck doesn't like them.
__________________
<< Insert long list of crap that's been purchased and bolted on to said vehicle here >>
Old 07-07-2009, 12:37 PM
zman17's Avatar
2000 Dodge Ram 2500
Your didn't say anything about any plenum check?
__________________
Old 07-07-2009, 12:39 PM
VWandDodge's Avatar
Quote:
What? Those aren't bolt on parts?
__________________
Tags
1500, 59, code, dakota, dodge, magnum, misfire, neon, p0300, p0302, p0331, po300, ram, random, van
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
Vendor Directory
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
