DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Trucks > Dodge Ram > 2nd Gen Ram
Thread Tools Search this Thread
Old 07-03-2009, 05:31 PM
dmack dmack is offline
Post P0300,p0301,p0302,p0307
1996 Ram 2500
5.9L Gasoline
106K mileage
Automatic Transmission
2WD
In park or nutural heavy gas results in lots of miss firing and sputtering to near stall. Very rough acceleration in D with lots of miss firing and sputtering must feather the accelerator to keep from stalling. However, when I manually run through 1st and 2nd acceleration is much smoother with fewer miss fires even with a heavy foot.
DTC: P0300, P0301, P0302, P0307
Freeze Frame Data
fuel sys 1 CL
fuel sys 2 CL-Fault
Calc Load(%) 9.22
ECT(*F) 206
STFT B1(%) -4.69
LTFT B1(%) 3.91
MAP(inHG) 5.91
EnG RPM 1600
Veh Speed(mgh) 28
Also, fuel gauge extremely inaccurate and reads empty 99% of the time.
Please help im lost.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 07-03-2009, 05:45 PM
zman17's Avatar
zman17 zman17 is online now
1998 Dodge Ram 1500
First , get a fuel pressure tester and check the pressure. should be about 49lbs. Second, do this http://dodgeram.info/tsb/2000/09-05-00.htm Third, check the cat. Fourth, check all fuses , relays and grounds going to the engine. If you still have a prob. get back to us. But I have to say it sounds like a bad cat.
__________________
98 1500 4X4 5.2,SC3815, HS 1.7's,Borgeson shaft,
Fastman TB, Hughes Plate, 4x4 Posi-lok
Magnaflow Cat. w/Flowmaster 50 series, Rock Solid Ram Steering fix
Tags
05, 37, code, data, dodge, fault, frame, freeze, fuel, missfire, p0300, p0301, p0302, ram, sys2
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
