i dont do much off roading so im wondering if i can get new gears like 3.92 or 4.10 for more power off the line. i have the stock 3.55. can i still keep the 1 wheel peel on there or will i need to change that ? i have 31 on there now i think maybe 33
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on Dodge Forums!
Vehicle: Ram 1500 4x4 5.9 auto reg cab 8ft bed Cherry bomb muffler k&n intake.
You need to change the front and rear. If you went to put it in 4x4. well I'm sure the others can tell you what will happen. You might as well go 4.10. Yea you can keep the one wheel peel out's.
If you go 3.92 gears, like the ones I have waiting for my truck in my closet, you can get a "thick" set that use the same carrier you have now. If you go 4.10 gears, you will also need new carriers.
Just a bit more money is all, still very doable. And like Laramie said, you will still have the open differential unless you install a LSD. Gears have nothing to do with open/LSD/locker/etc.
didnt know there were diffrent thanks
so where can i find 4.10 is it just 2 peices the spindle and the gears and just swap the 2 ??
Quote:
More correctly, what WON'T happen after that!
__________________
If parts ain't flyin', you ain't tryin'.
If it ain't broke, fix it 'til it is!
2009 Toyota Corolla S, 1.8L, 5-speed - the daily driver.
1996 Dodge Dakota, 4x4, extended cab, 3.9L, automatic. - my baby
Truck Gears. Richmond and Auburn come to me off the top of my head. Most will offer just a ring and pinion in the number you want. My suggestion is look for ones that come with "install kits". These will have new hardware,shims, etc. Lastly, having torched a few in becoming proficient in swapping gears out. This is not a quick,easy bolt on. Its not impossible,but you really have to pay attention when setting it all up. You will destroy your brand new gears on the test drive, if you don't do it right.
__________________
01 1500 XCab 2WD,5.2. Edelbrock/AEM Dryflow 14x3 RAC. Summit Performance Cap,Rotor,and 8.5mm wires hooked to Autolite plugs.MSD 8228 Coil. Superchips 3815. Royal Purple for the fluids. Hughes Engines Underdrive Pulleys, Hypertech 180 T-Stat. Bronze Truck Club #1
Vehicle: 2000 Dodge 1500 5.9, reg. cab short box, auto
The only thing that needs to be changed is the gears in the axle (and bearings/shims and whatever else).
By the sounds of your knowledge about gears, I would suggest taking it to a shop who specializes in setting up gears and let them take care of EVERYTHING... including buying the parts. It is definitely not an easy task, and special tools are required.
Paying a shop to do just a gear swap (no lockers or LSD) will cost probably $1000-1500 by the time its all said and done.
__________________ 2000 Dodge Ram 1500, 1 ton coils/Add-a-leafs, 3" body lift, 35x12.5x17 BFG Mud's
