DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Trucks > Dodge Ram > 2nd Gen Ram
Thread Tools Search this Thread
Old 08-29-2009, 02:43 AM
004x41500's Avatar
004x41500 004x41500 is offline
2000 Dodge Ram 1500
Vehicle: 2000 Ram 1500 4x4
Send a message via AIM to 004x41500 Send a message via Skype™ to 004x41500
how do you get the inner axle out? does it just slide out as well?
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
__________________
Ya, it wants to be a 6 cylinder...Cummins that is. WTC#18 Leveling Kit DIY Install 2nd Gen Video? Want a Prius? Read This First
Quote:
Originally Posted by OklaHemi View Post
take it from your elders; stay single, strap up and dont get caught up
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 08-29-2009, 02:49 AM
speeddemon31176's Avatar
speeddemon31176 speeddemon31176 is offline
1988 Ford Thunderbird
My Garage
Vehicle: 97 RAM 1500 club cab 4x4
After you remove the CAD housing you can slide it out of the axle housing.
__________________
1997 1500 4x4 club cab, Flowmaster true duals 2.25" with high flow cats, 4" Skyjacker susp./3" body, Cowl Induction hood-non-op.
Old 08-29-2009, 11:42 AM
Sheriff420's Avatar
Sheriff420 Sheriff420 is offline
2000 Dodge Ram 1500
Vehicle: 2000 Dodge Ram 1500 4x4 5.2
Send a message via AIM to Sheriff420
i left my intermediate axle shaft in when i changed that seal. i used a piece of threaded rod, some washers, nuts and the head off a sledge hammer as a seal driver.
__________________
I'm sorry, I can't hear you over the sound of how awesome I am.
Old 08-29-2009, 01:34 PM
Miami_Son's Avatar
Miami_Son Miami_Son is offline
2nd Gen RAM Moderator
Dodge Forum Moderator
2000 Dodge Ram 2500
My Garage
Vehicle: 2000 Dodge RAM 2500 V10 SLT+ Quad Cab 4X4
Quote:
What, no bubblegum or a safety pin, McGyver?
__________________
2000 Dodge RAM 2500 Sport SLT+ Quad Cab 4X4, 8.0 V10, 4.10 gears, Borla SS Headers, Edelbrock muffler, K&N CAI, KYB Shocks, Hell Bent 2" Level Kit, 17" American Racing Wheels (Baja), factory camper/towing pkgs, WAAG Sidesteps, member White Truck Club #87
Old 08-29-2009, 01:49 PM
Sheriff420's Avatar
2000 Dodge Ram 1500
hey, that's what the guy on pavement sucks said to do. he was pretty vague about it though.
he said,
Quote:
You will also need to build a seal driver from some all thread, some washers, nuts and sockets. Once you knock the old seal out (into the CAD area), fisht he all thread in, add the seal, socket, washer and nut. On the outside, add the other socket, washer and nut. This will be used a slide hammer.
he should have put a picture of that on the DIY.
the washers i had were the same size as the seals outer edge, so i didn't need a socket. but even if i could get a socket in there it would have screwed the new seal because there isn't a place to put the socket without messing up the rubber on it.
__________________
Old 08-29-2009, 02:40 PM
004x41500's Avatar
2000 Dodge Ram 1500
so just get some washers the size of the seal?
__________________
Old 08-30-2009, 11:46 AM
Sheriff420's Avatar
2000 Dodge Ram 1500
thats what i did. at first i had my dad on the outside of the axle tightening the nut to press it in but the washer started to sink into the lip of the seal. so thats when i had him use the sledge hammer head while i made sure it was going in straight. i had a hand on the washer on the end of the threaded rod and with each hit i had him push it back toward the diff to make sure the seal was going in correctly, then i repositioned it to the opposite side of the previous hit and had him do it again. .
i also wrapped some masking tape around the threads so they wouldn't chew up the new seal.
also, i used the hub nut socket to keep the threaded rod centered in the axle tube. i turned it around backwards and slid the rod through it, then when i was under there i had my right hand on the socket to keep it in the end of the axle tube and i had my left hand on the washer.
__________________
Old 09-01-2009, 09:56 PM
DODGEIT105 DODGEIT105 is offline
I believe there are two seals on the passenger side. One buy the differential and one at the CAD unit. I had the one at the CAD unit replaced awhile back. It doesn't require removal of the diff. But it did require removal of the CAD unit.
__________________
01'Dodge Ram 1500 QC 4x4
5.9 ltr, 4spd auto trans.
All AMSOIL in running gear
Old 09-02-2009, 04:26 AM
Sheriff420's Avatar
2000 Dodge Ram 1500
there is only one axle seal on the right side of the cad unit housing and the cad unit has a gasket on it.
__________________
Old 10-29-2009, 11:05 AM
anesthes anesthes is offline
Vehicle: 2000 Ram Laramie 4x4, 1987 Corvette supercharged
I'm probably going to do mine this weekend.
The seal, is on the RIGHT side of the car, so it presses into the right side of the tube.
Any reason not to use a hydraulic fork pressure and a socket to press it in? (i.e, a porta-power).
Next I need to fix leaking transfer case.. wtf!
-- Joe
Tags
1500, 4x4, 97, axle, cad, dodge, front, pavement, ram, removal, replacement, seal, seals, shaft, side, sucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
