DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Trucks > Dodge Ram > 2nd Gen Ram
Thread Tools Search this Thread
Old 07-05-2009, 12:30 PM
onegoodmason's Avatar
onegoodmason onegoodmason is offline
Vehicle: 95 1500 Reg Cab Shorty 4x4
Default Front inner axle seals , anyone ?
Hey guys ,
Doing the inner axle seals next on my truck , pretty much all I have left unless the engine dumps , lol . Anyone tackle these yet ? Any advice ? Is a case spreader manditory ? I know all about everything else except the actual seal install itself . Can iget behind it to tap it in , or is it really needed to have some reddi-rod and big washers handy ? The trucks been apart recently , had new bearings , u-joints , and ball joints , so the tear down should go without much issue .
What about the axle tubes themselves , what's the best method of cleaning them out . Obvious to me was how they broke , by picking up too much dirt reinstalling them after the new u-joints . I was thinking pressure wash but it's messy so I'm open to something you might have tried .
EDIT: did some searching , got some answers , can't delete threads ,
Here's a few pics , it's the start and basically were it sits now
Thanks , nice forum BTW
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 07-05-2009, 01:16 PM
Sheriff420's Avatar
Sheriff420 Sheriff420 is offline
2000 Dodge Ram 1500
Vehicle: 2000 Dodge Ram 1500 4x4 5.2
Send a message via AIM to Sheriff420
http://pavementsucks.com/tech/axleseal.php
__________________
I'm sorry, I can't hear you over the sound of how awesome I am.
Old 07-06-2009, 01:05 AM
dhvaughan's Avatar
dhvaughan dhvaughan is offline
Vehicle: 01 1500 4wd
^ the pavement article is pretty good.
to expose the drivers side seal, you have to remove the pumpkin.
i don't think it actually says this, but to remove the pumpkin you must slide out the drivers side axle, and the passenger side INNER axle, and to slide out the inner, you must remove the outer, and all the cad BS.
somebody recently sort of missed this, and hammered and pried on the pumpkin for a long time with the inner axle still in.
if i was serious about cleaning the axle tubes i'd use a piece of sch40 pvc pipe in whatever size will barely fit in the tube.
good luck.
we need a good DIY over hear. if you've got a camera and the patience for it, go for it.
__________________
01 1500 Reg Cab 4wd 5.2 auto 3.55 285/75/16 nasta step bar tow hook sc3815 180 3923 trans cooler/filter posi-lok powertrax noslip timbren brite-box pioneer head rockford amp/speaker cobra cb firestick hughes plenum water pump timing chain oil pump rear seal front bearings brakes shocks cracked dash towing composting boat.
Old 07-06-2009, 03:08 AM
Sheriff420's Avatar
2000 Dodge Ram 1500
one guy on here that recently did his u-joints used a framing square to scrape out his tubes. any stiff piece of metal with a pretty sharp edge ought to be good enough to scrape them out. then a shop vac or compressed air will get it all out of the tubes
__________________
Old 08-28-2009, 09:31 AM
anesthes anesthes is offline
Vehicle: 2000 Ram Laramie 4x4, 1987 Corvette supercharged
I have a 2000 Ram 1500 1/2 ton. I'm a little confused about the article.
Apparently I have a CAD axle, because mine is the auto locking nonsense on the passenger side. So is the seal NOT near the pumpkin?
I'm confused as to how to get the new seal in, where it is, etc?
-- Joe
Old 08-28-2009, 01:37 PM
cmckenna cmckenna is online now
Vehicle: 96 Dodge RAM 1500 4WD
I noted mine was weeping two weeks back when I had it up in the air. I just had it done last year- twice in fact and it's still hosed up. I didn't do it but another mechanic that I paid to do it over when the first round yielded all fluid pouring out upon turning the wheels.
I would like to learn how to do this so I can get mine fixed and not have to pay someone to f-it up more than it was to begin with.
Old 08-28-2009, 04:17 PM
Sheriff420's Avatar
2000 Dodge Ram 1500
http://pavementsucks.com/tech/hub.php
read this one. after removing the hubs and axles you will be ready to do the procedure in the axle seal replacement from post #2.
its not a hard job, there is just a bunch of crap you have to take off to get to the driver axle seal.
if it is your passenger seal then you're in luck because you just have to pull the axle to get that one. more than likely you have a bad u joint in whichever side is leaking and thats why it leaks more when you turn the wheel. for a new u joint and axle seal you will be looking at about 30$ to fix one side. which side is it leaking from?
__________________
Old 08-28-2009, 05:40 PM
It's the passenger side that is leaking.
Old 08-28-2009, 09:06 PM
004x41500's Avatar
004x41500 004x41500 is offline
2000 Dodge Ram 1500
Vehicle: 2000 Ram 1500 4x4
Send a message via AIM to 004x41500 Send a message via Skype™ to 004x41500
i too need to replace my passenger side axle seal. i read that tech article, but didnt read anything about the seal itself
__________________
Ya, it wants to be a 6 cylinder...Cummins that is. WTC#18 Leveling Kit DIY Install 2nd Gen Video? Want a Prius? Read This First
Quote:
Originally Posted by OklaHemi View Post
take it from your elders; stay single, strap up and dont get caught up
Old 08-28-2009, 09:14 PM
busaguy05's Avatar
busaguy05 busaguy05 is offline
2000 Dodge Ram 1500
The passenger side is the easy one. You have to take out the inner and outer axle and the CAD module and the seal is just inside the opening for the CAD.
Tags
1500, 4x4, 97, axle, cad, dodge, front, pavement, ram, removal, replacement, seal, seals, shaft, side, sucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
