DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Trucks > Dodge Ram > 2nd Gen Ram
Thread Tools Search this Thread
Old 07-12-2009, 07:41 PM
Hammer Down's Avatar
Hammer Down Hammer Down is offline
Vehicle: '01 Dodge Ram 1500
Default Shouldn't have swapped spark plugs
Yesterday, I changed my spark plugs and wires. The wires were replaced with the same as before, but for the plugs, I went from Bosch platinum 2 plugs to Champion coppers. The truck runs as smooth as ever, but it seems that my fuel economy has suffered. With cruise control set at 50, the overhead computer would vary between 17 and 21 mpg. Now at the same speed, the computer varies between 16 and 18 mpg. Could it be that the old plugs were better? or are there any other suggestions of what could have caused this?
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
__________________
'01 Ram 1500 360
White Truck Club #360
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 07-12-2009, 07:47 PM
Laramie1997's Avatar
Laramie1997 Laramie1997 is offline
The Moderator From Hell
Dodge Forum Moderator
1985 Chevrolet Monte Carlo
My Garage
Vehicle: http://www.cardomain.com/ride/3337823
Send a message via AIM to Laramie1997 Send a message via Yahoo to Laramie1997 Send a message via Skype™ to Laramie1997
That's probably from a heat range change.
Also, what did you set the gap at?
IMO, you did good by getting away from the bosch crap....
__________________
Mein Kampf- Yes, I have one of my own
Is now creating sigs Look
Red Truck Club Number 7
To vote in polls
1. Member for 30 days
2. 50 or more posts!
Old 07-12-2009, 07:48 PM
dodge15004x45.9 dodge15004x45.9 is offline
2001 Dodge Ram 1500
Vehicle: Ram 1500 4x4 5.9 auto reg cab 8ft bed Cherry bomb muffler k&n intake.
Send a message via AIM to dodge15004x45.9 Send a message via Yahoo to dodge15004x45.9 Send a message via Skype™ to dodge15004x45.9
You need to do yr mpg's long hand. I think it would be the other way around.
__________________
01 ram 1500, 4x4, 5.9, 3" top guns customz lift. PA truck club join here>http://dodgeforum.com/forum/dodgefor...ruck-club.html
Old 07-12-2009, 08:19 PM
I kept the old plugs in case, but I think I will try to run the plugs a little longer to see if there is any change.
__________________
'01 Ram 1500 360
Old 07-12-2009, 08:23 PM
aim4squirrels's Avatar
aim4squirrels aim4squirrels is offline
2001 Dodge Ram 1500
Vehicle: 2001 Dodge Ram 1500 5.2L 2WD Reg Cab Long Bed
Did you disconnect the battery when you installed the plugs?
If you did, you reset the PCM and it runs rich for about 200 miles or so before the adaptive learning leans out the fuel trims correctly.
__________________
Old 07-12-2009, 10:15 PM
No. I havn't disconnected the battery since I cleaned the throttle body last week. I've probably driven close to 200 miles since.
__________________
'01 Ram 1500 360
Old 07-12-2009, 11:15 PM
Sheriff420's Avatar
Sheriff420 Sheriff420 is online now
2000 Dodge Ram 1500
Vehicle: 2000 Dodge Ram 1500 4x4 5.2
Send a message via AIM to Sheriff420
i noticed a little less mileage and a little less power when i switched off of my bosch platinum +4s to the truck plugs, then i took those out and put the champion platinums in. all three are the stock heat range.
you need to check your mileage by resetting the trip meter when you fill up then the next time you fill up divide the miles driven by the amount of gas you used.
ie: 275 miles divided by 21.5 gallons = 12.79 mpg.
__________________
I'm sorry, I can't hear you over the sound of how awesome I am.
Old 07-12-2009, 11:16 PM
Sheriff420's Avatar
2000 Dodge Ram 1500
__________________
Old 07-12-2009, 11:19 PM
topsites topsites is offline
Oh yeah, forget the brand names, it's not that important, but what matters is you went from
a high performance double platinum plug down to a standard copper core one, there's less
conductivity hence your spark isn't as strong and the end result is a slower or less complete burn.
It all happens in a flash, but in time-lapse photography the stronger the spark, the better.
Them 2x platinums don't cost $4 each for no good reason
But you might try Autolites instead of Bosch, I think they might be a little cheaper.
Old 07-12-2009, 11:24 PM
A few dollars per plug isn't a huge concern to me. The reason I switched to Champions is that they are recommended by the service manuel, but if some other plugs work better, I have no problem with switching again.
__________________
'01 Ram 1500 360
Tags
10, 2001, 2500, bosch, dodge, easy, foul, plugs, put, race, ram, run, spark, sparkplug, tru
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
